wrinkled plane and wrinkles bump/displacement map
mCasualmCasual Posts: 4,607
edited April 2015 in Freebies
it's this image, click on it and save it to disk
because the ( too ) few times i added wrinkles to clothes models it always improved the look
i also posted the high polygon count object that was used to generate the bump map
https://sites.google.com/site/mcasualsdazscripts5/mcjwrinkly
Post edited by mCasual on
  • mCasualmCasual Posts: 4,607
    edited April 2015
    applied to a 1m x 1m plane with displacement strength 100%, min 0, max 2cm
    in case you didn't know, i have a script for DS 1,2,3,4 which can convert a displacement map into the-real-deal-morphs on a figure/prop
    https://sites.google.com/site/mcasualsdazscripts/mcjelevate-reva
    quick lazy test
    eventually i'll spend an hour to get a more credible wrinkle uhh composition :)
    2000 x 1125 - 1022K
    2000 x 1125 - 1013K
    2000 x 1125 - 1M
  • MilosGulanMilosGulan Posts: 1,991
    Wow just great :) thank You.
    edited April 2015
    the object i created to make the bump map
    in blender
    warped and subdivided further
    1280 x 720 - 345K
    1920 x 1080 - 297K
    Very interesting, btw where is that object, can it be downloaded and used in DS to make more similar bump maps?
    edited April 2015
    nm - time for a break lol ...
    Thank you Casual :-)
    Post edited by patience55 on
    edited April 2015
    the object is in a zip file named wrinkly.zip at the bottom of the page
    you also need the grayscale ramp image on that page
    then you apply that image to the object's diffuse channel and
    set ambient 100% and render this from a bird eye view camera
    if you wanted to create your own wronkles, you could use
    1 - create a wrinkled plane
    a modeler like Blender
    or
    mcjElevate
    or
    a primitive plane and dForms
    or
    mcjWarp
    2 - use the mcjPlanarUV script to project the UV coordinates from a side view camera
    3 - apply the grayscale and special surface settings outlined on the mckWrinkly page
    4 - render from a bird eye view camera
    ex:
    1 - zebra top camera view - note how the depth of the zebra is aligned with the Z axis
    2 - exported as a re-uv-mapped object (non-distributable by the way) using mcjPlanar uv
    3 - this grayscale ramp, vertical tiling -1.9 tiles, vertical tiling offset 0.05 ( 0r -0.05 if you render the other side )
    4 - the reUVed object with this ramp, 100% white ambient, 0% diffuse strength - one pure-black-light in the scene,
    960 x 540 - 254K
    512 x 316 - 10K
    512 x 512 - 13K
    1042 x 598 - 89K
    well this planar UV trick is not often seen
    you could make cameo pendants of your favorite characters and zebras
    or oversized belt buckles
    960 x 540 - 304K
    edited April 2015
    Thanks for explanation, very interesting indeed. I need to try this, to be honest I still am not practiced to make bump maps and make them work but should try definitely :). Thanks again for bits of wisdom ;)
    Post edited by MilosGulan on
    That is so kool. :-)
