Possibility for Genesis 9 to Genesis 8/8.1 Texture
Since i work mostly still with Genesis 8.1 and the Genesis 8 UV Set, i wonder if someone could make an Genesis 9 UV Set for the previous Generation so we could also use those Textures and Convert them with Map Transfer, that would be cool, or to give me an alternative way to Convert the Textures. i tried to make it in Blender with baking the Textures but i am not so good with Blender still with setting some things up correctly, since i also have some blank spots then.
Moved to product Suggestions as it is not a Daz Studio question. That said, using oone of the clone morphs (and then teawking) to get a Genesis 9 that matched genesis 8 in sahpe and then baking the maps from one to the other is an option. Otherwise, I think Cayman Studios has said they are working on a toold for using 9 maps on Genesis 8 Male/Female.
