Products hiding in Lost and Found
First, I would like to ask what the heck is the Lost and Found for? To keep us busy searching for things?
I purchased several items that ended up in L&F that I would prefer to be in their proper categories/folders. For instance, i found two products I purchased months ago, as well as one I purchased today in L&F. The are The Sewer and The Stairwell by Evilinnocence/RuntimeDNA and The Road to Madirac by Daz Originals/Anima Gemini/RuntimeDNA. I would prefer them to be in a folder I wouldn't have to search for. I've been placing some items in Content Library/My Library/Scene Subsets/Enviroments folder so I don't have to click all over the place to create a scene. But for some reason they would not copy into my folder.
So, what do I need to do to correct this problem?
Thanks in advance for your help.
  • Lost and Found should be otherwise uncategorised items. Note that a product will appear in every category to which at least one of its files is assigned, the product itself is not categorised. To categorise a file or files, or even a whold folder in the Content Linrary, right-click and select Categorise then check the categories you want assigned - if you need new ones right-click to create.
  • Thanks, Richard. I tried searching for the categorize option ealier but couldn't find it. I was trying to catergorize the whole folder at once. It don't work that way. I have to do each individual item and hope that are at least close to each other in the Smart Content/Files/Enviroment folder. But it looks is all goes in the a its folder under the Products tab. I haven't tried the Road to Madirac yet, but that's next.
  • NorthOf45NorthOf45 Posts: 5,712
    You can right-click on a folder and "Create a Category from" -> "Selected Folder..." or "Selected Folder & Sub-Folders..." All assets in those folders will be in their own category tree using the same folder hierarchy.
    You can select one or more assets in any one folder and right-click on one of them to "Categorize" to add to an existing category or make a new one. It is more granular if you want to separate the assets into different categories, but more time-consuming.
    In the Content Library pane, not in Smart Content (since those are not real directories).
  • Ron KnightsRon Knights Posts: 2,244
    It appears these Lost & Found items or problems were created on DAZ's side. DAZ should fix the problems, not paying customers.
  • That assumes that Lost and Found is a problem. it is the place for things not otherwise categorised - if you want them in a category you are free to place them there using the method above, but not doing so does not impede the functionality of the product. Yes, I would agree that older items that are not categorised at all should ideally be given fresh meatadata, but its omission is not actually breaking anything in the core application.
    Correction: the side of the author of whatever products you bought. Daz is merely the store, the artists are the one responsible for setting up a correct package.
    And yes, I agree that it can be annoying but..  it's also really easy to fix yourself.
    I believe metadta is done by Daz, not the PA - aside from anything else, the PA doesn't know the SKU at the time they upload the product.
    Well, I base this opinion on the fact that if you save something as an actual Daz Studio support asset (File -> Save As.. -> Support Asset) then this will involve quite a bit of meta data, including things like vendor name, item name as well as its compatibility base and category.
  • An unhelpful, yet slightly amusing comment:
    Up until right now, when I read this thread, I had thought my "Lost and Found" folder was a customized folder that I created myself.
    Because a couple of years ago, I had a chapter in my comic story called "Lost and Found", and I thought those were the files I used for it.
    I'm glad now that I didn't delete it, thinking it was files I didn't need anymore.   laugh
