Products hiding in Lost and Found
First, I would like to ask what the heck is the Lost and Found for? To keep us busy searching for things?
I purchased several items that ended up in L&F that I would prefer to be in their proper categories/folders. For instance, i found two products I purchased months ago, as well as one I purchased today in L&F. The are The Sewer and The Stairwell by Evilinnocence/RuntimeDNA and The Road to Madirac by Daz Originals/Anima Gemini/RuntimeDNA. I would prefer them to be in a folder I wouldn't have to search for. I've been placing some items in Content Library/My Library/Scene Subsets/Enviroments folder so I don't have to click all over the place to create a scene. But for some reason they would not copy into my folder.
So, what do I need to do to correct this problem?
Thanks in advance for your help.
  • Lost and Found should be otherwise uncategorised items. Note that a product will appear in every category to which at least one of its files is assigned, the product itself is not categorised. To categorise a file or files, or even a whold folder in the Content Linrary, right-click and select Categorise then check the categories you want assigned - if you need new ones right-click to create.
  • Thanks, Richard. I tried searching for the categorize option ealier but couldn't find it. I was trying to catergorize the whole folder at once. It don't work that way. I have to do each individual item and hope that are at least close to each other in the Smart Content/Files/Enviroment folder. But it looks is all goes in the a its folder under the Products tab. I haven't tried the Road to Madirac yet, but that's next.
  • NorthOf45NorthOf45 Posts: 5,929
    You can right-click on a folder and "Create a Category from" -> "Selected Folder..." or "Selected Folder & Sub-Folders..." All assets in those folders will be in their own category tree using the same folder hierarchy.
    You can select one or more assets in any one folder and right-click on one of them to "Categorize" to add to an existing category or make a new one. It is more granular if you want to separate the assets into different categories, but more time-consuming.
    In the Content Library pane, not in Smart Content (since those are not real directories).
  • Ron KnightsRon Knights Posts: 2,795
    It appears these Lost & Found items or problems were created on DAZ's side. DAZ should fix the problems, not paying customers.
  • That assumes that Lost and Found is a problem. it is the place for things not otherwise categorised - if you want them in a category you are free to place them there using the method above, but not doing so does not impede the functionality of the product. Yes, I would agree that older items that are not categorised at all should ideally be given fresh meatadata, but its omission is not actually breaking anything in the core application.
    Correction: the side of the author of whatever products you bought. Daz is merely the store, the artists are the one responsible for setting up a correct package.
    And yes, I agree that it can be annoying but..  it's also really easy to fix yourself.
    I believe metadta is done by Daz, not the PA - aside from anything else, the PA doesn't know the SKU at the time they upload the product.
    Well, I base this opinion on the fact that if you save something as an actual Daz Studio support asset (File -> Save As.. -> Support Asset) then this will involve quite a bit of meta data, including things like vendor name, item name as well as its compatibility base and category.
  • An unhelpful, yet slightly amusing comment:
    Up until right now, when I read this thread, I had thought my "Lost and Found" folder was a customized folder that I created myself.
    Because a couple of years ago, I had a chapter in my comic story called "Lost and Found", and I thought those were the files I used for it.
    I'm glad now that I didn't delete it, thinking it was files I didn't need anymore.   laugh
  • jjoynerjjoyner Posts: 887
    I bought a desktop computer last summer to advance my rendering capabilities beyond what my laptop computer allowed.  The desktop has Windows 11 Home, Core i9 14900KF CPU, 32 GB (expanded to 64 GB) of RAM, an RTX 4070 Super (by choice instead of a 500o series GPU) with 16 GB VRAM, an SSD boot drive (1 TB) and an HDD (4 TB).
    I deliberated on whether I should try to copy my Daz Studio, Poser and other content from the external HDD that I use with my laptop or install fresh with DIM.  After deciding that the copy option came with too many potential issues/headaches, I used DIM to install from my Product Library.  However, I now have more than 1300 products that have some files categorized in Lost and Found.  Some of the issue is likely due to some content being quite old but even some recent store content (such as M3D Kalen HD for Genesis 9, https://www.daz3d.com/m3d-kalen-hd-for-genesis-9) installed with some (not all) of its files categorized as Lost and Found.  I don't have this issue on my loder laptop running Daz Studio 4.21 and 4.24 Beta.
    Does anyone have any idea why so many items – especially new content – install with Lost and Found files?  I’m using Daz Studio 4.24.0.3.
    Thanks in advance.
    Lost and Found catches anything that is not categorized in some way (default or otherwise). That usually means the asset is missing metadata (if there is a metadata file).
    Anyway, this particular product has no metadata for the hair colors, no assigned categories, ergo, Lost and Found. There is also no Content Type, nor compatibilities.
    Pure omission on the part of Daz, since they are responsible for the metadata, not the PA. Although, I must admit, it can be a tedious job making metadata.
    Thanks for your reply.  As I installed content on my laptop over the past 6 years, I cleared Lost and Found items by manually categorizing them.  Over the years, that number of products may very well have been 1300 or so but I only had to address them in small batches as I installed content.  Now, I have them on my desktop all at once.  And I still haven't brought over my Poser content that did not come via the DAZ3D store.
    When I manually a product content from other sites, principally, Renderosity, but also older content from sites some of which no longer exist such as Runtime DNA, Content Paradise, Dreamlight, Smith Micro and others, I create a Product from the files so that it appears as an item in Smart Content and then add minimal metadata (just content type and category).
    Life happens …
    If you still have the old computer, you can export the user data and re-import it on the new one, either all at once, It only adds or replaces any metadata you created yourself. Of course, all at once will put all of the metadata it has, maybe for products you have chosen not to install. You could export user data per product, if you know which products you you updated, then import those. Tedious in every way...
    edited February 4
    I back up critical Daz Studio and Poser data weekly.  This includes my entire Studio/My Library/Runtime/Support folder which contains the UserData file.  The date of the current file is January 1, 2923 even though the latest file in the Support folder was last modified on February 1, 2026.  I’ll explore this avenue further.
    Update:  Because little is easy to find regarding Daz Studio documentation, I did a web browser search for exporting user data and got a detailed list (AI generated) on how to do it.  I’ve done so and now have a current UserData file that is twice the size of the old one.  That’s a good start.
    Post edited by jjoyner on
    Hello.  I decided to revisit eliminating Lost and Found categorizations other than doing so manually one product at a time.  Last summer, I started with more than 1,300 Lost and Found products after DIM installing my entire Product Library to my new desktop.  Each of the products had at least one item categorized as Lost and Found and some products had all of their content categorized as Lost and Found.  Most of the Lost and Found items were Poser file formats (cr2, mc6, pz2, cm, lt, etc.), some were old Daz Studio file formats (daz, etc.) and some were current Daz Studio file formats.  Most had no Asset Type metadata as well.
    I currently have just over 1,000 Lost and Found products remaining after categorizing Lost and Found content one product at a time over many months.
    Today, I exported my UserData_1.dsx file from my laptop where I have no Lost and Found content and copied it to my desktop at C:\Users\JoeJ\Documents\DAZ 3D\Studio\My Library\Runtime\Support.  I then ran Re-Import Metadata but the Lost and Found content is still categorized as Lost and Found.  I’ve also rebooted my computer.
    I also looked in my cms/ContentCluster folder and noticed a filed labeled dblog.txt.  I opened it and found many FATAL entries in it since it was created in 2025.  After rebooting my computer and launching Daz Studio again, the final lines in dblog.txt are
       LOG:  shutting down
       LOG:  database system is shut down
       LOG:  database system was shut down at 2026-09-18 16:32:02 EDT
       LOG:  database system is ready to accept connections
       LOG:  autovacuum launcher started
       FATAL:  role "JoeJ" does not exist
    My user name on the desktop is JoeJ.
    What have I missed or what am I doing wrong?  Thanks in advance for ant advice/help.
    495 x 502 - 137K
  • crosswindcrosswind Posts: 10,358
       LOG:  shutting down
    Only exporting / re-importing UserData won't work as these items are marked as "NO_PRODUCT" which will mess up your existing correct data while updating other data. UserData never works for me... therefore I always just replicate the cms database from my old PC to new PC.
    But you also can firstly fix L&F by correcting the categories, save to overwrite DSX file. Then re-import these products with the corrected metadata.
    As for the "errors" in dblog.txt, no worry, it's just a default check. We all have these messages... unless one manually created a role in cms by using his Win account name. The default role in DS's cms is "dzcms" (see screenshot 1)... you don't need to create a role of your own ~~
    942 x 662 - 33K
    Yes, I see the No_PRODUCT assignment in the UserData file on my laptop and desktop.  Before I make any sort of major move into the unknown, like copying the UserData file from one computer to another, I first protect the existing file by slightly changing its name.  If I need to revert back to the original file, I delete the new file version and change the name of the original file back to what it was.  On my laptop, I have all of my Poser content as well as content from other sites (Renderosity, Runtime DNA, RenderHub, etc.) and most of it is in my Daz Studio library (see attached screenshot of my Content Directory Manager.). I don’t have that content installed yet on  my desktop.  Will copying my laptop’s cms database to my desktop cause issues?
    I know that I can export the user data of individual files but can one import user data for individual files?
    OK.  Interesting …
    462 x 210 - 27K
    edited September 20
    Better have the same Library with all the assets installed...as same as the assets you have on your laptop, otherwise you will see orphaned reference of products as well as items in Smart Content ~  But you can remove orphaned products / items at any time...
    (* Back up the old cms before replication ~~)
    1) Export the corrected metadata in Content DB Editor (screenshot 1).  Then copy the runtime/support folders where all these corrected DSX files locate... to the library connected to your desktop. Re-import all metadata.
    2) Or, you can use this Script to import DSX files individually: https://www.daz3d.com/forums/discussion/618456/add-to-smart-content
    OK.  Interesting …
    1168 x 839 - 154K
    Post edited by crosswind on
    @crosswind,
    Thanks much for your additional info.  There seems to be so "simple" or "elegant" way forward for me with this.  Such is life.
    jjoyner said:
    @crosswind,
    You're welcome !
