Merging FAce Images From DAZ Figures
Nautious
in The Commons
Is it possible to merge two images taken from DAZ studio actors in a program like LoveChild? Please?
The reason I'm asking this is I'm looking for a way to make child characters in a graphic novel from the parents.
LoveChild works with photographs, as best as I am aware.
That's the idea I have for undertaking this project.
All help is greatly appreciated.
You could take one of the characters (the one matching the gender of the child), and simply dial in some other features until it matches what you have in mind, and then use a youth/child morph. Add a child skin on it, and you're done. If you are in Genesis 9, you even could simply mix both characters directly and then have a go at the youth/child morph.
oh yes it is Lovechild is perfect for that made to do that or face photos of course, do close upshots of both faces well lit though the default light should be fine, if you have the hd versions or even of only one of them use that in the parameters tab I maxed out the the subD and render subd levels, also in render settings -progressive render- rendering quality I go atleast 5. I did a combo of Babina 8 HD and Sanjay 8 I liked the result though there was a mark done the cheeks reason Sanjay I didn't zoom enough so proportions were out but stillcool than I created face in Facegen which also creates matching skin textures for the body oh and it has options to morph the head facial looks including aging from 20s to old as well as other ethenticities Zev0 has some programs to create shape child characters
oh Facegen works on genesis 1 up to 8 but not 8.1 or 9
