• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Auto Rig Pro quick rig - any DAZ video tutorials?
RR67RR67 Posts: 37
February 2023 in Blender Discussion
Disclaimer - I am very much a newbie with all this so I need guidance.
I want to make simple rotoscope animations in Blender using DAZ characters (the end goal is sending the animation back to DAZ for use later).
I have gotten the base G8 into Blender using Diffeomorphic, but it's hard to pose the rig. I've seen a lot of posts about Auto Rig Pro and its Quick Rig addon, but I haven't seen any video tutorials on how exactly I would set up my character with the Quick Rig (and maintain the DAZ armature). I have a general idea how the remapping works, but from my understanding the quick rig would streamline alot of this for me as there is a preset for DAZ already. It's critical to maintain compatibility with the original armature as I intend to import back to DAZ.
Anyway, before I buy the Auto Rig Pro and Quick Rig, I want to be sure I can get things setup as needed. Can anyone provide guidance on this?
  • TheMysteryIsThePointTheMysteryIsThePoint Posts: 3,272
    February 2023
    @RR67
    This one is by the developer. It was enough for me to make a G8 preset that works pretty well.
    And you might want to invest in the Animation Layers addon, and Pierrick Picault's "Alive" animation course, if you're going to keyframe things, and even if you are not, actually...
  • RR67RR67 Posts: 37
    February 2023
    Appreciate the suggestions, I will check them out!
  • benniewoodellbenniewoodell Posts: 2,000
    February 2023
    I don't have the link offhand, but Wolf359 has a couple fantastic auto rig pro tutorials on youtube that really helped me out. Maybe he'll see this and be able to drop the link for you.
    February 2023 edited February 2023
    I am still stumped... I cannot get the same rig movement as seen in this video (9:30 mark):
    Essentially when I click the hip item like the video, the body just stretches instead of bending the legs. The process I follow is:
    Under Auto Rig Pro, I select Quick Rig. Then I import the DAZ preset to fill in all the bones automatically.
    step1
    Then I allow it to clear any current mappings to make sure its only using the proper preset limbs.
    step2
    Finally I click Quick Rig and change it to Preserve. Since I want to export the final animation back to DAZ, I want to maintain the original armature function.
    step3
    I've tried turning on the options for 'Preserve Volume' and 'Retarget shape keys drivers', but it still does this when moving the hip.
    step4
    Post edited by RR67 on February 2023
  • JovanniJovanni Posts: 87
    @RR67
    It looks like you chose not the pelvis, but the lower abdomen. The pelvis is below. It is the small ones inside the yellow sphere.
    Bring the camera closer to the yellow sphere because there are several bones there. You can correct the size of the controllers just like the author of the video did.
    upd.: The pelvis moves only the pelvis itself and the legs. If you want to move the whole body, you need to select the bone Root_master.x It is located inside the yellow sphere I wrote about above
    Post edited by Jovanni on February 2023
    February 2023
    Thanks Jovanni. I had selected a higher bone in the last picture because it illustrated the issue, but I was getting the same result with the yellow sphere. I did find the bone inside the yellow sphere which moves the hips as intended, thank you.
    Is there any way to stop it from distorting like that for other bones though? I do get the same stretching when I use the yellow sphere to shift it left/right. Ideally the rig would limit the movement to the physical limits defined by DAZ (or what's humanly possible).
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
