G8enesis 8.1 male's Model Action Flaws
793043235793043235 Posts: 33
edited February 2023 in Daz Studio Discussion
When I was loading actions for genesis 8.1 male, I found that the legs of the model looked like this, and there were no strange deformations loaded. What's going on?
  • That looks as if there is a corrective morph kicking in when it shouldn't - apply yhe minimum pose (e.g. a knee bend) needed to show the issue, then in the Parameters pane option menu (the lined button in the top corner or right-click the tab) enable Preferences>Show Hidden Properties. Click the Currently Used group and go through zeroing the greyed out properties (hidden corrective morphs of the kind we are likely hunting) by alt/opt clicking on the slider and then undoing until you find which one makes the issue go away. Once you have a suspect click the gear icon on the slider and select Parameter Settings - that should tell you what it is from, check for updates and if you have the current version report it to the artist  or to Daz (for items sold here).
  • 793043235793043235 Posts: 33
    I followed your steps to open everything and didn't load any morphs, just the base model, don't know what's going on
    1444 x 896 - 967K
  • Richard HaseltineRichard Haseltine Posts: 108,517
    You need to do that with the figure selected, not the shin. This is what I have, with no shapes applied or bend fixers turned on so it shouild be just the base joint correction morphs (the three in the middle with almost unreadable labels).
    1102 x 565 - 107K
    Thanks, it did show some weird options, I turned it off and it was back to normal, thanks a lot, so professional!
