Suddenly main menu bar has changed?
MouserMouser Posts: 775
Not sure what happened but DS the main menu bar has moved the order of location of options as well as their drop down commands & options.
Also all of the installed script icons have been cleared (ex Turbo Loader etc).
The tools options are only a fractions of what they where?
I havnt updated DS itself recently so I am not sure what is going on.
Has anyone else run into this?
Post edited by Mouser on
  • Something has probably corrupted your layout files. Do you keep back ups? Have you saved your layout (Window>Workspace>Save Layout)?
  • MouserMouser Posts: 775
    I thought that, so I set everything back to factory setting and it remains as is.
    Everything so far looks to be working I am just confused as to the changes and wondered if anyone else had this happen.
  • Are you talking about the Smart Content drop down options under "All Products"? My drop down completly disapeared AND i could no longer down load new items from the smart content windo pane. the last update corrupted something. i had to do a complete reinstall, I mean complete. You have to find all those hidden window files and delete those then do a new install. Everything came back after that.
    That sounds like a database issue - did you get a complaint about PostgreSQL on launching DS?
    Well I dug up an old layout on a backup and it seems to have restored the default items I guess I'll re-ad the scripts etc again.
    Thinking on it, its been a few years since I did a fresh install...I cant wait.
    Its back again
    Uninstall
    Re-Install
    Still stuffed?
  • Something is damaging your layout files. Assuming you are not force-quitting Daz Studio during shutdown it is likely to be a system or security tool of some kind, or an outright folder/disc issue.
