Zeroing body parts on G9
teechurz_7c41d96282
I've been using Bone Minion on G9 and it works great, but the hands leave a little to be desired. Is there an easy way to zero the entire hand (or any other body part) back to its zero pose? Doing it by going through every part of the hand is tedious to say the least.
Any help would be greatly appreciated.
If you right-click on the hand in the Scen pane you can choose expand from Selected, then shift-click on the last bone and use the zero command.
I got it until the "zero command". Where is that? I don't see it anywhere.
Sorry, I thought you were using that - Edit>Figure (or Object)Zermo>Zero Selected Element(s)
But using that did the trick. Thanks!
