help with Dance of the Veils for Victoria 8?
sfishffrog
I just picked up Dance of the veils, and I can't seem to get the cloth to fit the model. I'm missing a step, but if someone knows of a tutorial showing how to use this priduct, I would really appreciate it. It looks good.
I load a gen 8 character, select a pose and select the corresponding prop, but the prop appears above and away from the model. i try to parent the veil to the model and to move it manually but it doesn't "fit"
Have you read the "Additional Details" section in the ReadMe here: http://docs.daz3d.com/doku.php/public/read_me/index/46681/start ?
i.e. You have the apply the morph to the veil that matches the pose you applied to the character.
By the way, if you are using a character other than Victoria 8 then the veil may not exactly fit to the figure, depending on how close the figure shape is to V8.
Ah, I was using Albany. Maybe that is what it is. thank you.
