Daz Shapes don't have effect
Hello,
I tried to apply shapes from "Z Curvaceous Model Shape and Poses" package.
https://www.daz3d.com/z-curvaceous-model-shape-and-pose-mega-set
For some reason, the shape didn't affect anything even I push the morph slide to 100%.
Did I miss anything?
Your advice is highly appreciated.
Best,
Josh
Please put the Viewport into a non-textured Drawstyle if you need to show a nude figure.
Do you have the Genesis 8 Female Body Morphs, and are they working?
I thought I had attached a screenshot. Sorry about that.
Most of morphs work just fine. Just few of them don't take any affect.
Mod edit: Image removed for nudity. Please see https://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
The screenshot attached earlier violated the regulation. The screenshot got fixed and posted here for your reference.
And do you have https://www.daz3d.com/genesis-8-female-body-morphs and is it working (I wasn't clear from the previous reply)
Hello Richard,
genesis-8-female-body-morphs working fine.
Best,
Josh
OK, click the gear icon on the slider for the problem shape>Parameter Settings, copy the Name (not the Label).
Help>Troubleshooting>View Log File, then search that for the name you just copied to see if there are any errors or warnings related to it.
Hello Richard,
No error found in the log file.
Anything else I can try?
Josh
But you can use, for example, the Fitness and Weight sliders?
