Help with showing indentation between characters and clothes on another character
Sorry if this is the wrong thread.
So in this instance say a guy has his arm around his girls stomach, how would you show the indentation of his arm pressed against her shirt and stomach?
Or if someone grabs another person by the arm, how would i create the creases and pressure  points created by the grab?
thanks
  • crosswindcrosswind Posts: 9,625
    edited February 2023
    There's no softbody simulation in DAZ, so some workarounds:
    Simple way: In terms of the body, you add smoothing modifier to the girl, set her Collision Item to the guy, then fine-tune their poses for getting a better collision result. For the shirt, there might be some poke-thru, but most will be hidden by the guy's arm & hand. Also give smoothing modifier to the shirt and use Mesh Grabber to fix the tiny poke-thru as needed.
    Or, use the product Ghost Dynamics to 'shape' the collission result https://www.daz3d.com/ghost-dynamics.
    There're also some freebies like X-Suit, you may get it from Rendo - Free Stuff place ~
    Post edited by crosswind on
  • DartanbeckDartanbeck Posts: 21,981
    Took the words right out of my mouth
    winkwink
    winkwink
    awesome. thanks for the info. will give that a try
