Blender doesn't keep the Daz poses.
Hi all,
I ve been trying all the week end, watching all the videos possible but i can t fix the issue.
I use the new bridge (not diffeo, becaus efor some reason the root path doesn t want to work) and i can't export correctly the poses to blender.
anyone knows or faced the same issue?
thank you!!!
You need to export with default pose then import a pose file onto your model in blender. that is how this addon works.
But, even in this way, official DTB may not import your pose file correctly.
There is an old bug hiding in the official DTB for years. There are 3 solutions:
1. Use diff daz importer
2. Use a modified version of DTB 2022, which fixed this bug. You can get it here:
https://github.com/butaixianran/DazToBlender
3. Fix this bug by yourself, by following this post:
https://www.daz3d.com/forums/discussion/544766/solution-for-importing-pose-issue-of-blender-bridge-bug-fix
Do you mean Diffeo?
Thank you let me check that!!!
