LIGHTSABERS - freebie addon for Laser Swords and Poses
MattymanxMattymanx Posts: 7,001
edited December 1969 in Freebies
This freebie is an addon for my set Laserswords and Poses
http://www.daz3d.com/laser-sword-and-poses
Lightsabers addon:
http://www.mediafire.com/download/jddiu9q82z0wijb/Lightsabers-Laserswords_and_Poses.7z
This free addon includes the following:
1 Mat file to hide the rectangular blade emitters on both the laser sword and staff
1 Alt Emitter for the Laser sword
1 Alt Blade for the Laser Sword
1 Alt Emitter for the Laser Staff
2 Alt Blades for the Laser Staff.
Before loading the Alt blades and emitters, please remember to select the laser sword or laser staff first so that they load up parented to the staff or sword.
  • HaruchaiHaruchai Posts: 2,040
    Thanks, really appreciated :-)
  • 3dTox3dTox Posts: 82
    edited April 2015
    I created an Iray shader for the blade. Follow the instructions in the readme file. To change the blade color, change the blade's refraction color.
    Iray blade shader
    840 x 525 - 28K
    Post edited by 3dTox on
    THank you very much 3dTox for making the Iray preset for it.
  • That Iray shader is one of the very few products I've been able to make work without using the DIM!
    After some experimentation with it, the refraction colour doesn't seem to do much to change the colour of the glow. However... If you change the refraction colour to white, changing the emmision colour is what apparently changes the glow, werdly enough! There will be some 'interference' of that colour along the blade's white core, however. Works relatively well, though.
    Iray blade shader
    Now that ShareCG is gone...  has the Iray blade shader been uploaed somewhere else, too?
    In any event, in absense of that, I applied Base Uber onto the existing blade, then upped the luminance a bunch,
  • It's funny in a sad way that I learned at this moment that ShareCG is no more because I had favored this discussion.  R.I.P.
    nomad-ads_8ecd56922e said:
    Iray blade shader
    You can use the shaders from these sets:
    https://www.daz3d.com/forums/discussion/505621/
