• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
about sculpting in Blender
MasterstrokeMasterstroke Posts: 2,363
January 2023 in Blender Discussion
If I want to import a mesh from DS into Blender and sculpting new details into it, does this mesh will loose its UV coordinates?
Iknow, it does happen in zbrush.
So what about Blender?
  • Cris PalominoCris Palomino Posts: 12,692
    January 2023
    As with ZBrush, you need to use methods and tools that do not add geometry and only reshape it.
  • MasterstrokeMasterstroke Posts: 2,363
    January 2023
    In fact, my purpose is to add geometry, not just doing morphs.
    So will UV coordinates get lost then as in zbrush?
  • felisfelis Posts: 6,137
    January 2023
    If you add geometry and don't redo the UV, the original UV will be used. But due to that, where you add geometry the textures will be stretched, dependant on how much geometry you add.
    But you can only use it as a new model, not as a modification of the original inside Daz Studio.
  • Richard HaseltineRichard Haseltine Posts: 109,463
    January 2023
    ZBrush doesn't lose the UVs, it does lose the groups (entirely, if using the GoZ bridge, with OBJ as an intermediary you get some choices). If you want to add new parts then consider using a GeoGraft, probably best making it in Blender and then using ZBrush to fine sculpt the mesh as you need to maintain a very precise alignment around the edges of the graft.
  • SDevSDev Posts: 158
    January 2023 edited January 2023
    If you do your renders in Blender, use a multires modifier and keep it. I'm using multires up to lv 5, multires won't harm any shapekeys/morphs or uv maps you have imported from Daz. If needed, you can bake the details to a displacement and export it.
    https://docs.blender.org/manual/en/latest/modeling/modifiers/generate/multiresolution.html
    Multires sculpting example in Blender:
    and
    Oh and a quick tip: When in Sculpt Mode, press the F key to change the brush size :)
    Post edited by SDev on January 2023
  • lilweeplilweep Posts: 2,795
    you can always wrap the orignal Genesis (and thus its UVs) onto non-conserved geometry
    Post edited by lilweep on January 2023
  • marblemarble Posts: 7,500
    January 2023
    Good question and something I had also wondered about because I am clueless when it comes to creating UV maps. I have often thought that I would like to add details to clothing such as shirts that open or zips that unzip. We often get shirts with buttons but most of them do not open - same for zips. However, this kind of modification causes a whole new world of complexity what with UV re-mapping and transferring rigging, etc.
    Whether it is ZBrush or Blender or Marvelous Designer we are faced with the same problems.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
