SY Genesis 8,3,2 Clones for Aiko 3 and Hiro 3
Ethin
@SickleYield would it be possible to do Genesis 8,3,2 clones for Aiko 3 and Hiro 3.
Post edited by Ethin on
Ethin
To or from? It is not possible to AutoFit to older, pre-Genesis figures as they don't use weight-maps that can be projected into the clothing..
I see, and thanks for the straight to the point answer as well.
So unless there is some other way to convert clothes from Genesis # to pre-Genesis figures, then I guess the matter is closed.
@Richard Haseltine A question, where does AutoFit get the weight-map info from, a file or from the figure loaded in a scene?
Evilinnocence's CrossDresser program can convert clothes from Genesis 1 to earlier figures, including Aiko and Hiro 3. Program itself is free, you need a license for the figure you're converting to.
Thanks Leana.
So that route I would just need to convert stuff back to Genesis1 and then use CrossDresser to go to A3/H3.
I can manually fit Genesis 1-2 stuff to A3/H3, it works ok, but it's a lots of time up front and a bunch of fixing after posing, an automated process would save me about half an hour per item every time I wanted to use Genesis era stuff.
