Interactive lessons cover the whole window
So I'm use the studio for the first time, and I want to do the interactive lessons. However, when I start an interactive lesson, the entire window goes gray except for the message in the middle. I get prompts pointing to grey squares telling me to "Click," but clicking doesn't do anything. I don't know how I'm supposed to learn anything with the lessons hijacking the whole window.
I have an ultrawide monitor. Is there a way to run these lessons outside the studio window?
  • Halcon BlueskyHalcon Bluesky Posts: 720
    edited January 2023
    bienvenunet, If you have an Ultrawide Monitor try to set properly on Windows 10/11.
    I am using Windows 11, but the functions would be almost the same.
    Go to Settings, Display.
    Look for Scale, use the monitor reccomended scaling this can range between 150 to 300%
    Now look for the Display resolution it will depend on two factors the supported display resolution for your monitor and the video card in your computer, if your video card is not an Nvidia RTX or AMD RX series, the display resolution could be limited  to a max of 1980 px
    Also you should have installed the monitor display driver.
    2687 x 2017 - 286K
    Post edited by Halcon Bluesky on
