Show Us Your Bryce Renders Part 12
15657596162100
  • adbcadbc Posts: 3,115
    Horo : very interesting fantastic renders, the anaglyph looks really like walking in the valley, like NGartplay and mermaid mentioned.
  • HoroHoro Posts: 11,407
    Thank you adbc.
    2 abstracts, some tori, a plane, a sphere and a light.
    adbc - just noticed them in the gallery. Very beautiful abstracts, the second one with the blue is awesome.
    Horo : thank you.
    edited January 2023
    The terrain is from High Resolution Terrains 1 given a material combined from Landscapes under Fantastic Skies and High Resolution Terrains 3. Sky and ambient light by an HDRI from Sunless HDRI Skies and the key light by the sun.
    Barren Land
    1200 x 800 - 213K
    Post edited by Horo on
  • mermaid010mermaid010 Posts: 6,089
    Adbc - very nice abstracts.
    Horo - another outstanding landscape, love the atmosphere.
  • NGartplayNGartplay Posts: 3,389
    adbc, beautiful abstracts.  Especially drawn to the blue one.  So surprising how changing up lights and views can make different images.
    Horo, your high resolution terrain work is amazing.  The ground looks so real.
    mermaid, NGartplay : thank you.
    Horo : smashing terrain, great material and sky.
    Thank you mermaid, NGartplay and adbc.
  • Fencepost52Fencepost52 Posts: 513
    edited January 2023
    Hello, friends, and Happy New Year!
    Took a long holiday and now I'm back to this thing called Life. Lots of awesome stuff going on and I'm going to add a few things to the mix.
    The one titled "Great Hall" had to be post-edited in GIMP to create the horizontal mirror effect.  I don't know if it's possible in Bryce or if I'm doing something incorrectly, but when I create a "vertical mirror" and offset it in each axis by 0.01 it still leaves a noticeable seam and the mirrored portion doesn't reflect the image properly (the colors don't match and some areas are brighter and others darker).  The mirror has no color or anything else that I can figure out which would create this issue.  If someone knows how to get around that or the reason why it doesn't work, I would greatly appreciate your information.
    Art
    960 x 540 - 807K
    1920 x 1080 - 2M
    1080 x 1080 - 1M
    960 x 540 - 181K
    Post edited by Fencepost52 on
    Fence, ewwweeee, those are fabulous abstracts.  Kaleidoscope in Bryce.  I don't know what Gimp can do (thought it was a modeler) but these are so complex.
    Wow Art fantastic abstracts, I agree complex but very beautiful.
    It seems like the upload is working.
    Fencepost : Fantastic abstracts, very sophisticated.
    edited January 2023
    Fencepost - good to see you here. 4 beautiful abstracts. I don't know what happened with the seams. For that kind of mirror, the infinite plane is usually the best option.
    By the way, when you add the image to text, do not forget to limit horizontal size to 800, it seems that your images are wider.
    Ah yes, upload works again. I just replaced my last 5 images and don't need them on my website.
    A tilted terrain with the open underside is from HRT-2 with a material from HRT-1 and the fields in the ground from Vegetation. The boardwalk comes with Bryce 7.1, Michael 3 is from Daz 3D and the camera was self made. Background and ambient light by an HDRI, the clouds from Bryce and the key light by the sun.
    Vantage Spot
    1200 x 800 - 206K
  • huberthubert Posts: 417
    Horo:
    - Fascinating "Mordor" terrains. I really like the mat/colorscheme of the "silver-copper" variant.
    - Your "High Resolution Terrains 3" landscape has great atmosphere and depth. Not to forget the terrain mat.
    - Your most current scene looks like some happy spelunking. Great POV/view!
    adbc: Cool stuff! Great reflections and coloring, esp. in the 2nd one.
    Fencepost:
    - A cool series of abstracts! Wonderful pastel softness in the first one. Great reflection and pattern in the following three. The silver+golden one is my favoritee.
    - No idea about said disturbing seam. -- Like Horo, I too suggest to try with an infinite plane mas mirror. Or try to tilt the camera very slightly by 0.01 degrees. Did you disable all atmosphere effects (esp. haze and fog) to avoid their possibly negative impact?
    Horo - fantastic work, Michael has an excellent view.
    Thank you hubert and mermaid.
  • HansmarHansmar Posts: 3,147
    edited January 2023
    NGartplay, No problem. I know that you can choose to keep limits (for poses) or not.  Some poses exceeding limits will result in very strange results. I try to prevent those.
    Hubert, thank you. And spectacular abstracts you made.
    Horo, the Mordor-based terrains look very weird. The realistic terrain is very, very realistic with a wonderful texture and great sky too. The one with the man is a very nice point of view.
    I made two different renders from the same scene. A bridge from a DAZ architectural set, multiplied to make it longer. A free low poly figure, Millenium Dragon 2 and a humming bird. Streaming light effect by David Brinnen and HDRI enhanced skies by Horo. And, hooray!, uploading works again!
    1370 x 659 - 654K
    1370 x 659 - 490K
    Post edited by Hansmar on
    edited January 2023
    Thanks for the compliments, everyone.  Every time I open Bryce I'm amazed at what it can.  It's so sad it's not moving forward.  I've shown my work to other artists and when I tell them it's Bryce, they're not only amazed, but they tell me that it can do things their softwares can't.
    It's interesting to note that these scenes aren't complex at all.  A primitive or 2 with textures, mirror, and bump map create all the magic.  There really is no complexity to the geometry, just the magic of reflections and Bryce.
     GIMP is similar to Photoshop, but it's free and open-source.  I only used it here to mirror the left side of the image.
    Thanks for the feedback.  I am using an infinite plane and discovered that the atmosphere was on, so I disabled everything and no change.  Also tried rotating the camera slightly as well as the plane, but no improvement.  I'm going to experiment more and if I can't find my error, I'll post the Bryce file for y'all to take a look.
    Thanks, Horo, for letting me know about the image width.  I wasn't aware of that and I'll fix that so the images show correctly.
    Art
    edited January 2023
    Hansmar and Horo and adbc: nicely done!
    Horo, I like that you put a park ranger in the scene and a walkway.  It gives the cave/arch a theme.  Nicely done.
    Hansmar, both views of the bridge look wonderful.  The first is more dramatic in that the shadows are more intense.  The second one is moodier.
    edited January 2023
    hubert, Fencepost : thank you.
    Horo : very realistic view on a beautiful landscape, great atmosphere.
    Hansmar : wonderful renders, love the streaming lights that makes the effect different on both views.
    A simple render with the Millenium dragon.
    754 x 754 - 69K
    Post edited by adbc on
    Hansmar - two very nice images with the different lighting.
    Adbc - simple yet beautiful, the atmosphere is awesome
    edited January 2023
    Hansmar - thank you. Both renders with the dragon look great. Difficult to decide which one I like better.
    Fencepost and NGartplay - thank you.
    adbc - thank you. Beautiful dragon render. This red sky goes beautifully with this scene.
    Actually the same terrain as above but rotated, The rocks in the water are lattices, the sand and sea are terrains and the Songbird from Daz 3D. The sun rays are from Environments - Inclement Weather. Sky and ambient light by an HDRI and the key light by the sun.
    Sand Beach
    1200 x 825 - 136K
    mermaid, Horo : thank you.
    Horo : The terrain looks awesome in a total different angle, water sand, rocks and bird are a nice addition the landscape, beautiful sky as well.
    The dragon is perfect in your render adbc.  The red fits the theme as well...great job on this.
    Horo, the rays are so pretty; love the different look from the other.  really nice.
    edited January 2023
    Superb realistic scene Horo, the rays, the sands, the rocks and the bird work together perfectly.
    An underwater scene using a coral reef freebie from ShareCG, I added some plants and did the underwater effect using one of David's tutorials.
    1000 x 500 - 355K
    Post edited by mermaid010 on
    mermaid : outstanding underwater scene, beautiful atmosphere, looks very realistic.
