Camera Nano
I'm rotating the Camera  around in the main window selecting different parts of  a model  to group.  Too see the Selected & Static meshes better I upped the wireframe resolution. When I went back to the camera controls instead of the main work window moving, I get a nano previews above the camera tool being using. When I let go of the tool the main window jumps to that position. I launch another instance of Bryce & the main view port rotated using the camera tools.  I have never seen this before. Does anybody know if it's a bug, or an Easter Egg like feature?
  • HoroHoro Posts: 11,404
    Interesting. No, I have never seen such - but then, I almost never use the Director's view.
  • This is just a tool. It's called Nano-Editor and you turned it on on the right side.
    If it is active, this preview appears regardless of whether you are working from the director or from the camera.
  • S RayS Ray Posts: 405
    drachenlords: Yea that is it. Thanks. I never used it before, I must have activated it when I enabled the Plop Render option below it.
  • You are welcome. Can happen quickly. I never use it either, but Bryce has quite a few adjustments to suit everyone's taste. But I don't know anyone who really uses them :D
