How to get sand stuck to a sweaty body
Toobis
If someone is playing a volleyball game on the beach they'll sweat and inevitably in that game will tumble and get a bit or perhaps a lot of sand stuck to their bodies. Is there an effect to do this on G3g8f?
You could probably do this with Parsis.
Good suggestion but a bit out of my price range. I don't suppose theres any other ways.
I would use UltraScatter Pro and use one of the scatter surface patterns.
Isolate the sand particle(s) you want to scatter and then choose the body part and part surface area by using a mask.
Rotate and resize the particle during the scatter.
You could surface scatter several particles with different size, shape and color.
It is a bit advanced but it would work like a charm.
You could also use a spattery brush in your painting program of choice to draw an opacity map, apply that to a geoshell on the figure and apply an appropriately "sandy" texture.
a decal might work if it's not an animated scene
https://www.daz3d.com/iray-grungeworx
https://www.daz3d.com/krdx-dirt-fx
https://www.daz3d.com/rl-dirt-fx--volume-2
K i'll look into these thanks.
