Strange wrinkles under breast when bump enable (G8.1 Female)
I can't find a way to erase this wrinkle.
I zeroed all the morphs, including the hidden properties,
I tried every setting of the Breast Utilities for Genesis 8 Female(s) and Breast Control Genesis 8 Female(s),
I added a smoothing modifier to the figure (and it just became worse),
none of these worked.
It only disappeared when I went to Surface -> Body -> Bump Enable and turned it off.
But I really want to keep the bump setting on.
Could anyone give me some clues,
or is there any tool can fix this?
I would really appreciate it.
It's probably normal rather than bump maps, made for a different figure where the crease was in the shadowed area.
Hey! Richard,
I had the same thought as you at first time,
but then I found that there are no bump maps for the figure,
it's empty.
So the only option I have is turning Bump Enable on or off. : (
