[Released] Ultimate Pose Converter Bundle for Genesis 9 [Commercial]
13
  • carrie58carrie58 Posts: 4,175
    inquire said:
    OK, well, there's something I could do: Parmeters and Zero the arms. How about duo poses not matching up, as in romantic or wrestling poses? For the second screen shot, it would not be apparant that the poses are so far off if each were presented as a single pose. But, as this is a wrestling hold, the lighter guy should be grabbing the other guy's arms.
    So are they hiarchal poses?if yes then make sure that one of the 2 figures is parented to the other. if not there will always be adjustments needed unless you are using the exact same figures that the poses were created with. Just part of the whole posing thing .......
  • inquireinquire Posts: 2,464
    @carrie58: I agree, but it seems to me that when I used Bone Minion to go from G3 romantic poses, and applied them to G8s, they applied pretty closely. When going from G8 to G9s, there seems to be more separation or errors. Maybe it's that there are so many more movable parts to a G9. But I was hoping that RiverSortArt could find a way to make the poses transfer more accurately. Or, maybe it's not possible. I'm just hoping that it is possible.
    Are you making sure to use the Zero limits on the G9 figures? Yeah going from G3 to G8 isn't that much of a difference,cause most of the changes were in the head , but G3/G8 to G9 is a much bigger difference ...... I found that it's a major help to just having smaller adjustments,and being able to use the poses I already have .......
    @carrie58: Welll, Bone Minion recommends turning off limits. But I do zero the figure poses, placing each back in a zero pose position before applying another pose. If the figure gets into that distorted arm pose, I delete it and call up another G9.
    Yup and I recommend using the provided "Limits Off" script , I had some really funky things happen when I didn't  ,so far I've just popped through the poses with Bone Minion , I don't bother zeroing the poses inbetween unless one gets funky ,then I just zero pose ,if the arms act up I go to the parameter tab to fix that .
  • inquire said:
    Also, when working with G9s, I often use wrestling poses. Sometimes, with the Bone Minion used to apply poses, the two characters do not meet. Sometimes, one is transitioned higher than he should be. The Y transition has to be adjusted. At other times, one character is in the air, off the floor, and his legs are placed at odd angles. The other character seem OK in this second case.
    I have a screen shot, but this is actually one of the better pose results. Still, you can see that the arms are not positioned correctly. If it can't be any futher corrected with your product, it still saves time. So, I'm not trying to state a big complaint. Yet, it seems to me that this doesn't happen with transferring poses, using Bone Minion, from say G3 to G8. So, I just thought I'd make you aware of this.
    I should also note that I'm on a Macintosh, using OS 12.6.1, and DAZ Studio 4.21.0.5. Please see the screen shot.
    The y translation might need to be adjusted.  This is something I struggled with for months and finally just lived with it.  The height of the hip is different between the two generations so a pose that actually modifies the hip Y value will often be wrong (usually for kneeling poses, lying poses, etc but it could happen with any pose).  I tried adjusting for the difference but that did not work either.  A lying pose might NOT need a Y adjustment while a walking pose might.
    For the zeroing pose problem, I don't know if it ONLY G9 or not.  I always used the CTRL-SHIFT-F and it never showed up.  Since you reported it, I used the actual Zero Figure Pose and it can show up there.  Bone Minion transfers values to all non-locked transformations on bones, whether they are hidden or not. There are some transformations in G9 that are hidden but not-locked and Zero Pose does not seem to catch it.
    So, does it make a difference if the Zero Pose ends up with the arms bent? If a pose is then assigned to the G9, will it be as it should be? Or, is it necessary to straighten the arms out?
    It won't make a difference IF the pose assigns values to the arm bones.  If it does not, the arms will stay akimbo.
    Actually, with this product I can get better poses by using, for example, a G8 pose on a G9. I think that's because of all the additional bending possible with a G9: spine 1 to spine 4, uppper arm twists 1 and 2, thigh twists 1 and 2. The pose can seem more natural. So, this is a very fine product.
    Thank you!  Yeah, Daz did a good job with the twists.  They were a pain for pose converters but they help make the figure give more natural poses.
  • kyoto kidkyoto kid Posts: 42,443
    edited December 2022
    ...oops almost made an error as I thought that the G8 bundle was to G8 from all the listed Generations not the other way around.  So to transfer from all four older generations to G8, I would need to purchase a separate one for each, correct?
    Post edited by kyoto kid on
    That is correct.
    ..thank you.  This will be a lot kinder on my system and in the long run, my budget as well.
    You're welcome!
  • k886860k886860 Posts: 12
    This is a great product!! I have used numerous pose change products in the meantime. I have tried at least all products and scripts, both free and paid. All products in the past were converted similarly, but they could not be used without fine-tuning. This is because it takes too much time to re-modify the converted pose, so finding a similar pose product released for the current character can save time. In fact, it is true that I had many doubts about how well this product would convert, but this product shattered my doubts. Finally, you don't have to fix your hand pose!! And the pose of the two characters combined is almost perfectly transformed!! Some poses can be reproduced with only minor adjustments without destroying the original pose. With this product, I have been able to render scenes with a new generation of characters using poses I have collected as a hobby for almost decades (I have collected many poses since victoria in zygote and poser3 in metacreation). This is truly an innovation.
    If there's anything I want from the creator, I've been waiting for a tool that can somehow reuse characters before victoria4 (I'm victoria3, vicky, and literally Paleolithic poses without deleting them. In the past, I tried using tools like philc's puppet master, but the results is not good.) Can you also make the conversion possible? Other users may have the same thoughts as me, but if there is an auto script that converts and saves the entire folder at once, it will be a great product that can not find the slightest flaw. I would be happy to purchase an add-on product if such functionality was added.
  • RiverSoft ArtRiverSoft Art Posts: 6,972
    Thanks for the kind words!  I am glad you like it.
    Unfortunately, I came to the Daz Studio game too late.  I do not even have a single pre-V4 character or pose.  As far as converting the entire folder at once, that goes against the philosophy of the Universal Pose Converter.  I wanted to stop people from littering their entire HD with conversions of poses and just use the poses directly.
    edited May 2023
    In order to create a converter that supports pre-V4 characters (Victoria3, Michel3, Freak3), do you need only a basic character and a few poses that can be referenced for production?
    Even before V4 became popular, there were many poses that came out with V3.
    (Especially, I still own pose DVDs for the V3 and M3 sold by German producer Schlabber, who was a famous pose maker.)
    I paid him and order 15 years ago living in Germany and received a DVD of his poses by mail internationally.
    Even then I was living in Korea (I live now).웃는
    http://www.schlabber.org/index.html
    This is because the more poses, the better, regardless of generation.
    No matter how great the current generation is, if there are not enough poses to support it, a person who lacks creativity like me can't overcome it.
    So, if there is a converter for the pose of the older generation, I would like to render it using it.
    V2, V1, and Poser's Possett, which predate V3, are too old characters.
    I can't ask you to make converters up to that.우유 부단
    (Because I doubt if anyone actually uses it now.)
    Post edited by k886860 on
    Yes.
    만나서 반갑습니다! laugh (나는 지금 한국어를 공부하고 있어요. k-dramas 너무 너무 너무 좋아요! laugh)
    Does this site only have V3/M3 poses?  I can see if I can find a free V3/M3 character somewhere to try it out.
    i send message to you (daz mail) smiley
  • crosswindcrosswind Posts: 10,318
    @RiverSoft Art
    I re-posted the issue to this correct page: haha ~
    Now the Minion for G8 >> G9 cannot correctly work. Pls help to check the issue:
    1) Load Minion G8F to a G9 Base;
    2) Load Pose Preset: Base Pose Kneeling B.duf in Genesis 8 Starter Essentials to the Minion. (ss1)
    3) The values of Twist properties on almost all Joints are wrong now..., as well as tiny difference in YRotates and ZRotates. For instance, Left Upper Arm ... a comparison in (ss2)
    Pls also check this thread: https://www.daz3d.com/forums/discussion/718801/minion-issue-g8-g9#latest
    I tested these in both DS 4.22 and 4.23. Many thanks !!
    Edit: Besides, similar issue happens to Minion G3 for G9 ( pls check Pose Preset: Fashion Model Pose 03.duf in Genesis 3 Starter Essentials ) .
    235 x 128 - 26K
    235 x 128 - 23K
  • crosswind said:
    @RiverSoft Art
    I assume you turned off the limits on the figure?
    edited January 2025
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    No, rotation limits are turned on. (ss1)  But it won't work either if turning Limits off ~~
    And pls be noted that you have to make sure you test with the latest G9 Starter Essentials package, dated last November: http://docs.daz3d.com/doku.php/public/read_me/index/86958/start
    2560 x 1392 - 784K
    Post edited by crosswind on
  • crosswind said:
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    When I get back to my Daz computer, I will test.  Rotation limits need to be turned off.  The other common source of error is that the original pose uses pose properties, e.g., Right Hand Grasp.  If it does, you have to use the Heavyweight Bone Minion to get good results.
    RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    I got what you mean: Rotation Limits need to be ALL turned Off beforehand! Now it works. Thank you very much!!
  • crosswind said:
    RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    Great!  I am glad you figured it out.
  • RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    HI! Thanks for your quick reply over here. I'm the person from the other thread that first posted about this problem and I appreciate the info.
    Since this explanation was new to me, and I know I must have used the G8 minions on G9 umpteen times without any problem, any idea what could cause this to pop up? I'm particularly worried in that I've bought a lot of G9 figures and utilities in recent weeks/months. Or am I just crazy? wink
  • paulawp (marahzen) said:
    RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    RiverSoft Art said:
    crosswind said:
    @RiverSoft Art
    As I replied in the other thread,  you probably just got lucky smiley  Rotation limits need to be turned off on the figure.  The other common source of error is if the original pose uses pose properties, e.g., Right Hand Grasp.  If it does, you have to use the Heavyweight Bone Minion to get good results.
  • Hi all. I'm having a huge problem with the bone minion for a specific morph. It changes the pose of the minion, but doesn't transfer over to the model. Is there a solution for this? Thank you
  • jmucchiellojmucchiello Posts: 2,307
    I bought this bundle a while back in the expectation of using it. And I finally did. After creating the minion, there's a popup dialog telling you it was created. That's fine. But when I load the DUF again later, the dialog also pops up stopping mid-load until I hit OK. That's not so great. Anyway to prevent this from happening?
    More than likely this is a partial pose that does not change the hip. In those cases, you need to execute the Apply Changes script.
