Why does G8F take FOREVER to load?
2»
  • GordigGordig Posts: 10,787
    Wonderland said:
    Gordig said:
    Wonderland said:
    I HATE ONE DRIVE! I wish I could figure out how to disable it completely.
    Open up Task Manager, go to the "Startup" tab, right-click on Microsoft OneDrive and click Disable.
    Ah thanks! I was a lifelong Mac person until I got into DAZ Studio and iRay. Will that disable it completely?
    It will prevent it from launching at startup, which means unless you launch it manually, you shouldn't need to worry about it again.
  • Wonderland....
    I was curious... what is your G8F Load time?
    You will get an annoying popup from time to time telling you One Drive not Connected. I have it disabled and get the popup with diferent time periods, sometimes two ore three times a month, or a week, sometimes two or three times a day. I hate Windows and would go to running 100% Linux if it wasn't for Daz and one or two other applications that I use. My Linux machines give me very few problems where Windows is a constant PITA
  • AnotherUserNameAnotherUserName Posts: 2,727
    edited December 2022
    https://www.daz3d.com/turbo-loader-for-genesis-8-and-81
    Turbo Loader will absolutely help you with your load issues and save you some memory for rendering. I do not use any of my G8 or G3 figures without it. It takes a little time to set up but it is completely worth it. If turbo loader dosent help significantly than im not sure what the issue with your product would be. I was in the same boat though. I have so many characters and morphs that it was taking a ridiculous amount of time to load my figures.
    Post edited by AnotherUserName on
