Show Us Your Iray Renders
Adding to Cart…
Yep. It's otherwise particular about the specific size/ratio of the images, as noted above.
And yes ... that's the way I've been using HDR so far. Use it as a lighting source giving some cool reflections and effects on the objects in your scene and that's it and add a similar background in postwork, which you can tweak with curves in Photoshop.
As far as quick and easy results, use the built in Sun-Sky dial. I found that once you go to photometric lights or IBL it takes a lot longer to render.
And sickleyield ...... thanks a million for your advice on this forum and on DA.
Well go figure, I did quick search and wouldn't you know, its in my downloads library. I probably picked it up then too.
http://www.daz3d.com/hydra
...for me only Lisa's Hydrangea shows up. Not very threatening unless you have a severe pollen allergy.
Still want the original Creeper.
I'm finding what works well is start with environmental HDR, then add maybe a point or spot with flat geometry to it to add some more directed lights, and tweak the two luminances until they play well.
If I'm doing a scene I usually like to stick to emission objects within the scene, though I might add some extra lights if details need to come out.
You're welcome!!
I found a Glitch in Iray... Ooops! :P
ROFLMAO - Okay....best one yet. :)
Kat
Kat
Ooeeehhhh .... Iray broken :-)
One of my hopes is to have a decent core of flexible models to reasonably capture various ethnic groups without having to buy specialty items constantly.
I had bought Skin Builder, to that end, and was a little dissatisfied at first... I decided to experiment using that plus Victoria 6 HD base (yay $2.99 sale!)
I've figured out that the problem I was running into before was messing around with overly saturated colors, which was flattening a lot of the cool details skin builder creates. Aaaah.
This model also uses the G2F morphs, which I think reasonably captures the look of a black woman (though she looks a touch like Australian Aborigine)
There's also Real Hairy armpits and the tank shirt dynamic item (not completely happy with the texture)
I am mostly pleased with the result, though I've been poking at sclera texture a bit.
I found, notably, that for black people you really want to shut off 'crush blacks.'
(Also it looks like I really ought to get that 'muscle flex' for G2F. Mutter)
Another beach side beauty, this time with a wet tshirt...
(Regular Genesis 2 male, I don't have Michael 6 yet, but again experimenting with morphs).
Edit: Blah, just realized I didn't do anything with his hair, which destroys the wetness element... working...
That is a pretty good wet fabric effect.
...need to get a wet kind of look on the platform of the train station.
Taking a break today though.
Surprisingly simple! Just translucent white, with a bit of gloss.
I discovered it by accident on my previous thing, but it's less socially acceptable posting that on a woman, sooo
Ok, fixed it a bit.
Once I have a feel for what I want, I hide all of the figures and concentrate on the HDR . It is a nusance that you can only se it when rendered.
Setting the sphere to finite and the scale multiplier to around 4 or 5 has been a reasonable start on the files I've been using. I also start with a camera focal length of around 100mm.
After that it is trial and error to get the two to match up. It is both time consuming and frustrating but I haven't found a better way yet.
I keep forgetting about Ctrl+L... One thing I've done that seems to work fine, something I read about in one of the many Iray threads, is to include a normal spotlight. Iray will ignore it, but you always have some light on the scene. I suppose you could parent it to your camera, too.
Anyway, just another way to do the same thing. It's all about what works best for the way you work. :)
Her skin looks really good. I could live with that shader! :coolsmile:
Her hair looks a lot better. I'm glad that thread was helpful for you.
First test with Iray, took about 10 minutes. took a 2 year old scene and just rendered it in Iray
lighting comes out a lot better in Iray, looks a lot more realistic even with my hacked 3 point light rig used.
hah! Beauts!
He does look a bit apprehensive. Perhaps just being prudently wary in case a "bug" tries to sneak up... like that glowing-eye'd, mechano-spider from several pages back.
man, that is pure awesome impressive. (as were ALL the scenes done using that "feature".) Look what that Jag11 unleashed... he could have kept that secret and been the ONLY person that could do those cool effects. Most of us would be thinking he photoshop'd it. ;)
Kudo's to Jag for experimenting, and then sharing! And to Sickle for writing it down, and handing out a test scene! And to everybody else that tried it and posted their personal results. way cool. Gotta love this community.
Gad zooks I want to go try that out, but it took me 160 minutes to get caught up on this thread. If I'd have read "that" page first, I could have dl'd it, started a render, and even on my other faster-but-CPU-only rendering it would have been done by now! grrr.
that's sweetly nice! Since your efforts were to "properly light/texturize" red wine, let's focus on that. Excellent!
I mean, the rest look good, and darn decent even, but the wine glass kind of looks "more" real than the other's. ;) The never ending battle of tweaking things until "all are equal" I suspect.
Was those reddish tinge's around the bottom of the glass from "caustics", or just plain Iray IOR, or was it more of a "reflection" of the red cloth underneath? Either way, it looks really good! Just a bit curious, because if the cloth was White, or say Green, would you get a different effect? Artistic License and all that, but if you had a nice snake-skin cloth (hehe) would the wine look Snakey? Or I suppose the proper thing to use would be a Skunk cloth/skin shader - "that wine looks skunky..."
Not the right glass? Since wine comes in a box, are you sure it has the right to decide what shape of glass it gets spilled in to? It should be happy it gets a glass at all, never mind getting picky about the shape!
Although, if you extend that and make a Cognac shader, then yep, glass shape is going to matter.
My father was a wine snob, so I just laugh at it all.
Actually, I used volume effects! I grabbed a wine glass with filled liquid from a free site. I could have modeled it myself, but ... saved me time. Also, getting the upper bit with the liquid tension is a lot trickier.
Base color: 55 11 18
Refraction: 1.36 (I don't know if that's 'right,' but close enough!)
Refraction weight: 1
Transmitted measurement distance (note that the wine glass is probably half a meter tall, in the scale I used): 20
Transmitted color: 96 9 35
No SSS.
Changing the transmitted color darker will make the liquid more 'opaque,' lighter will make it more transparent.
I used a similar effect for the iced tea I did a few pages past.
And now back to trying to tweak my render so it doesn't keep grinding to a halt after a dozen iterations. mutter
My father was a whiskey snob. and a beer snob. anti-snob actually. "pffft! I could get three of those for the price of one of yours. Seems silly. If I wanted something tasty and pretty, I'd have ordered a broccoli-in-a-fancy-glass."
except Cognac... every body seems to get that. ;) My Aunts are all into Sherry... I don't get that.
Wow. you know, that is 100% right!!! I KNEW there was something that look real about that, but I couldn't put my finger on it.
The liquid meniscus, and the shading it gets... wow... Totally cool! You spent the time to get that right, and I totally couldn't see it - because it just looks right, and what my "eye" expected. That's pretty awesome! Without that, I bet it looks like... not as good.
that's totally weird how such a subtle thing, is totally not all that subtle to your actual eye - if it's there, you don't even notice; if it's not? it looks goofy!
Nice! Way to pay attention to details!
so now I feel like a total dick. "Yeah, just throw that on the bottle! Easy peasy!" ewwww. that's gonna take some effort to get the liquid "tension" happening.
wow. Iray is PB "R" - not PB - do-what-I see-in-my brain...
I'd be interested in seeing what you "want"... If you can do all these things in other implementations of Iray, I'd love to see what you got going? What are these things you find missing? serious.
I mean, DAZ has been more than super-supportive about Iray, (already one update because of user requests,) so if you ask, who know's... Maybe you get it! It is called a Beta, so that suggest requests are "requested"...
You want something, ask.
I've spent days playing with all the settings and I actually came here just now to ask how about how to position an HDRI map without rendering, only to find out you can't.......Gadzooks.
That is indeed problematic.
I don't understand how or why they designed the program that way.
I was on nvidias website watching an Iray Seminar video, and on the version they are using, you can very easily position the map without rendering.
I really hope they fix this for the official release.
There is a fairly easy way to position the HDRI. Hide everything and set the draw style in the top right to Iray rendering. this is how I set up all my non-plain environments
