Where to find Morph Loader Pro in Studio 4.7
HeadwaxHeadwax Posts: 10,562
Hya, new user here, trying to work with wrinkle 3d and Studio.
I was wondering if someone could point me towards the Morph Loader Pro button in Studio 4.7
thanks in advance :)
    It normally pops up by itself when you import an OBJ file.
    It is on the 'Creator ' Toolbar, which you can enable in the Customize pane (F3). Go to the right in Customise, open up Advanced and Toolbars, then right click on 'Creator Tolls' and Enable it. You should see it on the Toolbar right away after pressing Accept.
  • HeadwaxHeadwax Posts: 10,562
    thanks very much JimmyC_2009, I'll go and check it out,
    much obliged!!!! :)
    cheers
    I failed in following the instructions, :( but I found it on the left after pushing F3 and gave it a shortcut key and now I can get it to make an appearance ;)
    Thanks again!
