Is it possible to use only the head of G8F for morph loader?
James
So export the head, change it, import it back.
James
No, but if you chnage only the head then that is all the morph will affect - what are you hoping to do by exporting only the head that you cannot do otherwise?
I'm experimenting wtih zwrap. I want to wrap a head.
The problem is although I have masked all the G8F body to prevent it to be affected, but after the process of zwrapping, though the body shape doesn't change, but the body angle always change.
Could you make a new subtool before using ZWrap, then use that as a source to paint the original shape back in?
