Is it possible to use only the head of G8F for morph loader?
So export the head, change it, import it back.
  • No, but if you chnage only the head then that is all the morph will affect - what are you hoping to do by exporting only the head that you cannot do otherwise?
  • JamesJames Posts: 1,190
    I'm experimenting wtih zwrap. I want to wrap a head.
    The problem is although I have masked all the G8F body to prevent it to be affected, but after the process of zwrapping, though the body shape doesn't change, but the body angle always change.
  • Could you make a new subtool before using ZWrap, then use that as a source to paint the original shape back in?
