Adding to Cart…
Leftover from preview renders for an upcoming set.
It didn´t find it´s place in my final selection, but I didn´t want to throw it away, so I thought I´d post it here.
Hi all!
The next Easy Environment is around the corner, visiting the Highlands. ;)
It comes with a cloudy daytime and a cloudy sunset option, Iray and 3Delight.
Hope you´ll like it!
In the cart. Looks beautiful.
Thanks for the support JOdel. I hope you´ll get some nice renders out of it. :)
Hi can the cross be hidden?
Hi Serene!
Yes of course. Both the cross and and it´s stone socket are separate objects you can hide or delete from the scene.
Ah, excellentt! On the list!
Thanks Greymom, glad you like it. :)
I kinda forgot to properly mention it already released ...so... it already released. ;)
https://www.daz3d.com/easy-environments-highlands
Hi guys!
The ExoPlanet series is about to see it´s 8th entry. ;)
ExoPlanet VIII features floating isles connected by thick roots. It comes with a day and a sunrise version for both Iray and 3Delight.
The Iray scene includes a (subtle) volumetric cloud touching the lower parts of the isles (you can remove/edit that of course).
It should release towards the end of the week.
I hope you´ll like it!
This one again looks very promising, Flipmode! I love the jungle hills!
Thanks caravelle, glad you like the misty jungle. ;)
Thanks eric (swedish?
), glad to hear it.
Danish ancestry. :) By the way, which product was used for that pic at the top of the page with the dragon heading into the sun?
Ah Danish. ;)
I had a gaming buddy with "Olsen" as surname, thus my bad guess.
The image was done with the "Over the Sea" set.
https://www.daz3d.com/fma-over-the-sea-hdris-and-skyspheres
No, that was a good guess! And thanks for reminding me of the Over the Sea set, need to break it out and have some fun.
Glad to see your new release, will pick it up later today!
Thanks!
Yes, time for the obligatory "set released" post.
Well...
> Set released ;)
https://www.daz3d.com/easy-environments-exoplanet-viii
Here´s a Non-Promo image I did yesterday for fun (allowing myself a bit of postwork)
Really nice new set!
Yes!
It's still in my Product Library; I'll download it later.
Thanks Leana and caravelle! Glad you like the set :)
One more "extra" image I did just for fun (not a promo) >
Hi guys!
Just to let you know, some change in Daz Studio 4.22 broke some HDRIs, and most of my Easy Environments sets seem to be affected.
I reported this during the Beta, and reported it once again right now for 4.22. I hope Daz finds a solution for it quickly.
I´ll keep you updated as well as I can, but my life is a bit off-rails right now, I am in the middle of a move.
As temporary fix you can try resaving the .exr textures with Photoshop or Gimp.
(Thanks Laurita for the suggestion in the Technical Help thread https://www.daz3d.com/forums/discussion/comment/8415026/#Comment_8415026 )
Sorry for the trouble, let´s hope it gets resolved soon.
Hi guys!
The 4.22 issues mentioned above should be fixed now via product updates.
If one of your Easy Environments products doesn´t load the HDRI properly (showing as pink background) please check if there is an update available for that set (e.g. through DIM).
I am sorry for the troubles, and appreciate your patience. Thanks!
If you notice any remaining issues, please let me know so I can take a look at it.
Trying out 87678_FMA Exo Orbits HDRIs and Skyspheres
Looks good, except for a couple that appear as a thin strip of color a few pixels wide on a black field.
FMA EO P01 Lush Mid Iray.duf
FMA EO P04 Lava02 Low Iray.duf
Coincidentally, a fresh version of part -02 appeared in DIM since I downloaded the update, but nothing has changed. I noted that each part has a full set of presets in common, a little unusual if they aren't always synchronized to ensure they are the same throughout.
Thank you for the updates!
Thanks for the report!
Yes, I see it, it´s a mistake on my end.
I´ve fixed it here and will submit it to Daz tomorrow.
Thanks for the patience!
It's just the ,exr files that are being updated, right? And that only affects the Iray version?
Great! All these check out okay (still a few new ones to install):
Easy Environments: Hell DS
Easy Environments: Stairway to Hell
Easy Environments: Winter II DS
Easy Environments: Snowy Mountains Iray
Easy Environments: Road to Nowhere
Easy Environments: Clouds II DS
Easy Environments: Clouds DS
High Peaks Skydome and HDRI DS
Eternal White Skydome and HDRI DS
Green Hills Skydome and HDRI DS
I believe so, yes, on what is being updated - and yes, it was Iray's image handling code thatw as having issues - but that might have affected other engines too (especially if they use the same library).
