LogTemp: Warning: DazToUnreal: ERROR: Unable to parse DTU
macos 12
I builded UE5.2 and Daztounreal2022 with xcode.
it dipalyed some some warnings but builded successed.
When I send an animation to UE, Log shows LogTemp: Warning: DazToUnreal: ERROR: Unable to parse DTU
At this stage, do I have any good way to fix it?
This doesn't seem to be a big problem, but I'm not good at c++
Thank you
DTU FIle content:
"DTU Version" : 4,
"Asset Name" : "Genesis8Male",
"Import Name" : "Genesis8Male",
"Asset Type" : "Animation",
"Use Experimental Animation Transfer" : false,
"Asset Id" : "Genesis8Male",
"Content Type" : "Actor/Character",
"FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male.fbx",
"Base FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male_base.fbx",
"HD FBX File" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/Genesis8Male_HD.fbx",
"Import Folder" : "/Users/liuyu/Documents/DazToUnreal/Genesis8Male/",
"Product Name" : "",
"Product Component Name" : "",
"Materials" : [
"Version" : 4,
"Asset Label" : "Genesis 8 Male",
"Material Name" : "Face",
"Material Type" : "Iray Uber",
"Value" : "Actor/Character",
"Properties" : [
"Name" : "Asset Type",
"Label" : "Asset Type",
"Data Type" : "String",
"Texture" : ""
"Name" : "UV Set",
"Label" : "UV Set",
"Value" : 0,
"Data Type" : "Double",
"Texture" : ""
"Name" : "Smooth On",
"Label" : "Smooth",
"Value" : 1,
"Texture" : ""
"Name" : "Smooth Angle",
"Label" : "Angle",
"Value" : 89.9,
"Texture" : ""
"Name" : "Line Preview Color",
"Label" : "Line Preview Color",
"Value" : "#000000",
"Data Type" : "Color",
"Texture" : ""
"Name" : "Line Start Width",
"Label" : "Line Start Width (mm)",
"Value" : 0.1,
"Texture" : ""
"Name" : "Line End Width",
"Label" : "Line End Width (mm)",
"Value" : 0.1,
"Texture" : ""
It's too long. I can only copy part of it
Attach the log rather than trying to paste it into the body.
Is this ok?
It works after i changed "Intermiediate Folder", It may be caused by Chinese characters.Thank you!
