Issue with AJC College Times Outfit for Genesis 8 and 8.1 Males
I'm having a weird quality issue with AJC College Times Outfit for Genesis 8 and 8.1 Males. I'm not sure if it's something wrong with the product itself or if there are just some settings I need to change to fix it. Here's the store page:
https://www.daz3d.com/ajc-college-times-outfit-for-genesis-8-and-81-males
It looks great in the promos, but when I'm rendering there are a lot of blocky "facets" and some really weird artifacting in the crotch area when a genital bulge is dialed in. I have attached a render of a character with the clothes set to render at SubD level 3 or 4 and with a smoothing modifier added. And another screencap of what it looks like in Daz with the view SubD at level 2, out of the box with no smoothing modifier applied. The bulge is dialed to 100% in the second image to better show the weird jagged edges and shape that it creates. In the render it's at 50%.
Whenever I've encountered something like this before, cranking up SubD fixed it. Is there anything else I can change to make the outfit render more like the product's promo pics?
The crotch issue is especially weird because I've seen it on another newer outfit as well, but it was created by different PAs. I've never had this issue with other male clothing. The other product is Shadow Realm Outfit for Genesis 8 and 8.1 Males:
https://www.daz3d.com/shadow-realm-male-outfit-for-genesis-8-and-81-males-bundle
  • FenixPhoenixFenixPhoenix Posts: 3,241
    edited November 2022
    I have the outfit and just checked it out and you are correct! The issue is really visible, especially when you use the light color options! I thought maybe it would've been set up to use with dforce, but that was not the case. I'm going to also submit a ticket because I don't think I'll be able to use the pants otherwise.
    466 x 723 - 367K
    476 x 722 - 378K
    Post edited by FenixPhoenix on
  • I don't have the set, but is there a Rigidity map interfering with the morph transfer in the groin?
  • LindseyLindsey Posts: 2,017
    Try the outfit on one of the supported shapes.  Says on the product page "Other Shapes may be supported in Daz Studio by Auto-follow"
    Here's the outfit on three of the supported shapes: Michael 8, Owen 8 and Lee 8.
    666 x 906 - 139K
    666 x 906 - 130K
    666 x 906 - 122K
  • pseudocriticpseudocritic Posts: 4
    Aha! Thank you! This fixed all the "faceting" issues. His previous shape was primarily Torment 8.1 with some custom character shapes blended in. I approximated the same look with Michael 8.1 and Lithe which are supported, and it looks great now. I've always used auto-follow, I had no idea using the supported shapes made such a difference. Excellent knowledge to have. I attached a new pic of the character so anyone else visiting this thread can see the before and after. EDIT: Oh, the earlier pics were deleted. Well, the new one is currently attached all the same smiley
    The remaining issue is the crotch area, unfortunately. It still has that jagged edge problem, I assume because it's not a supported morph? I tried using the Fit Control morphs and it still has the same problem.
    I'm not entirely sure how to check this. The few google responses I found weren't super helpful. Where would I look for this?
    1507 x 1265 - 1M
    Post edited by pseudocritic on
  • SDwitch to the Joint Editor tool, in the Tool settings pane click the icon at top-left for Vertex Mode, and, with the trousers selected, see if there are any entries in the main area under Rigidity Groups. If there are, click the +  next to them and see which areas light up.
  • felisfelis Posts: 6,508
    Shouldn't it be Geometry Editor?
  • barbultbarbult Posts: 27,509
    Yes, it should.
    It was indeed Geometry Editor, and there wasn't anything next to Rigidity frown  I've never done a morph in ZBrush before—for anyone who has, is that something relatively easy to do and would it even work for the item if it deforms using existing  but non-supported morphs? I may just use it without altering the gens area, but I do prefer it for a more realistic look. Thank you everyone for your help so far smiley
    D'oh. Sorry.
    You might try exporting the troublemaking sweatpants without the trouble making morph dialed in as an obj and then reimporting the obj in the Morph Loader Pro with the character's morph fully dialed in and that will transfer the morph to the pants so you dial it there. At least that's how I think how to could more easily fix it.
