Adding to Cart…
Looks like this is for the shortcut only, what I wanted to get is to start the second instance just by clicking on the correcsponding DUF file. I spares a lof of clicking.
Has anyone tested the script on 4.21?
And if it does work, can someone dummy-down the steps for me, please?
I use it all the time on Win11 and DS4.21. Remember that you need to edit line 1 of the script and set $dspath to your DS install directory:
$dspath = "C:\Daz 3D\Applications\64-bit\DAZ 3D\DAZStudio4\DAZStudio.exe" #Change to your Daz Studio Path.
After you have done that:
Right-click on the script and select "Run with Powershell", see attached image.
Thanks. :) I'll try that.
Do you prefer the script or to use the beta version as a secondary instance?
I never use the Beta versions, unless a spectacular new feature has been implemented.
