Adding to Cart…
@LLSS-3D It looks like it was mostly likely done in-house at Axis Studios for Magic: The Gathering – War of the Spark
https://axisstudiosgroup.com/work/magic-the-gathering-war-of-the-spark/
You could ask Zombietaggerung who made one of the Daz3D Loki Helmets if they can make it. For a cheap freebie alternative, use one of their Loki helmets and hide the horns.
Superhero Helmets (Loki)
https://www.daz3d.com/forums/discussion/332616/superhero-helmets
Kid Loki's Helmet by zombietaggerung (at Rendo)
https://www.renderosity.com/freestuff/items/88761/kid-lokis-helmet
I guess someone got Taggerung to make it 'cause here it be: https://sharecg.com/v/99326/
I search a Princes Leia bun hair style for Genesis 8
Is he a weightmapped DS figure? Don't worry I found him...lucky I had him downloaded but not installed.
Would this or something similar do you? It's a very quick prototype. At the moment I've weightmapped Grugglemonk to be able to pose it but I could once done export it as a cr2 which should work with the figure.
There's no uv or surfaces at this point but if you tell me what sort of surfaces you want I can probably do them.
Wow thx a lot, this is not only the hair , it's the whole package. :)
Did a bit more work. No uv's yet.
UV's done. Anyone know what settings to export a cr2 at?
Hi, I'm looking for an animation for Genesis 3 Female, a simple walk, maybe back and forth. Do you know where I can find it? Thank you.
If you want a proper HP version, all you must do is ask :-) Happy to oblige.
@Pendraia Looks like you made a bodysuit for Gruggle Monk! If you want to export your outfit as a .cr2 file, try and follow the steps by Richard Haseltine and Andolaurina at this thread...
Please...Steps to saving model .CR2
https://www.daz3d.com/forums/discussion/1605/please-steps-to-saving-model-cr2
On another forum, someone suggested doing a FBX export from DS, then import into Poser, and export as a CR2.
Also @Catherine3678ab states, "btw - Gruggle is a legacy figure, it is to be found in the Poser runtime ;-) When you make mat files in D/S, those must be kept in another folder under My Library but NOT in the runtime folders."
Source: https://www.daz3d.com/forums/discussion/544646/40-diffuse-base-textures-for-the-gruggle-monk-tshirt
And here's an old and short YT video showing the process..
export cr2 form DS to Poser
https://www.youtube.com/watch?v=sgiDZI2OcVA
I seek free poseable rope or twine, with knot ends.
I could use Ajax's poseable tube. I would just need a twine texture to put on it. But I would still need a model of a knot end as well.
Any suggestions welcome.
Thanks for the info. I have managed to create a cr2. It also works with the gruggle monk cr2 as a duf file which I was really surprised by. At this point I'm just refining and tidying up before doing a final save. Then it will need testing. Poses I did for gruggle monk will be released at fantasies attic Halloween freebies event. I just need to get the files to them.
@Pendraia Glad to hear you found those cr2 links helpful. I'll keep an eye on Fantasy Attic, but unfortunately, I missed getting the Gruggle Monk freebie and the link to it, on the 3D Universe page, is no longer active.
@lukon100 Maybe some of these Freebies Ropes and Freebie Knots will help you out...
Small Wooden Bucket Free low-poly 3D model by LemonadeCG at CGtrader (Hide the bucket and you have a knotted rope)
https://www.cgtrader.com/free-3d-models/architectural/decoration/wooden-bucket--3
Posable Rope by BionicRooster at Rendo (Includes Rope Textures)
https://www.renderosity.com/freestuff/items/62918/posable-rope
Rope (DAZ3D; Iray; obj included) by SmidA at Rendo (Includes Rope Textures)
https://www.renderosity.com/freestuff/items/91435/rope-daz3d-iray-obj-included
9 commonly used rope knots by vincent-page at CGtrader
https://www.cgtrader.com/free-3d-models/sports/equipment/9-commonly-used-rope-knots
Braided rope Free 3D model by nicocha7777 at CGtrader
https://www.cgtrader.com/free-3d-models/military/other/braided-rope
Rope Tileable PBR Material Texture (Substance Designer) by thoma-marcotte at CGtrader
https://www.cgtrader.com/free-3d-models/textures/miscellaneous/rope-tileable-pbr-material
Low Resolution Knots In OBJ Format by 3DCheapskate at ShareCG
https://sharecg.com/v/67887/view/5/3D-Model/Low-Resolution-Knots-In-OBJ-Format
Easy Pose Rope by BionicRooster at ShareCG
https://www.sharecg.com/v/54282/gallery/11/Poser/Easy-Pose-Rope
ep konts rope by aemi1970 at ShareCG
https://sharecg.com/v/91727/related/11/Poser/ep-konts-rope
Rope Procedural Free by burkan2 at CGtrader (for Blender)
https://www.cgtrader.com/free-3d-models/various/various-models/rope-procedural
It's sad that some of these characters are no longer available but can understand why they may have done it.
Thanks much, Robertswww!
I think my best option is BionicRooster's poseable rope, with one of the knots from Vincent-Page. I applied a texture I got form someone off RenderHub, but tilted the images 45 degrees.
Anyway, I tried these things and so far I like the results. It's all for this project of making the character, Oskar Metzerath, from the novel called "The Tin Drum" by Gunter Grass. The rope goes over Oskar's shoulder to hold up his tin toy drum. I looked at stills from the movie adaptation to make the drum in Blender and PhotoShop.
While this rope solution will likely work, there's still much to do, like rig the little triangular rings and figure out the right rope length by trial and error. But here's my first sloppy attempt:
Looks good...
@lukon100 Glad to be of help and it looks like your project is coming along nicely! I agree that it takes a lot of trial-and-error to get things just right, but that attention to detail pays off on a nice looking finished project.
I'm looking for a particular hat, I've always heard it called a visor or sun visor. Golfers sometimes wear them, and dealers at casinos, I've seen them at the beach as well. I'm looking for one to fit G8M (AM's Chimpanzee for G8M, to be specific), but honestly i could probably use any generation (or even just a prop) and just parent it to the head. Has anyone seen one of these? Pictures from a search engine to give you an idea of what I'm talking about. (odd, for some reason the pictures did not attach?)
https://www.wilmapsdigitalcreations.co.uk/view_product.php?id=116
Thank you very much, that should work just fine!
I am hoping someone could point me in the right direction. I am trying to find those clear small condiment cups with lids, used to hold ketchup or melted butter. Sometines they call them sauce cups or portion cups. I would really appreciate the help.
@Cupcake Those sauce cups with lids are hard to find. I did find some on Free3D but they are not free :( They look nice, but they're $9 - Maybe someone else will have better luck finding a freebie 3D model of them.
Little Sauce Jar (Empty) 3D Model
https://free3d.com/3d-model/little-sauce-jar-empty-8769.html
@robertswww I appreciate your help. I was begining to think they did not exsist anywhere. I'll take a look over at what you did find.
Maybe someone who has some spare time can make one up.. if they would wish to. I would be grateful..
@richardandtracy Thank you for that idea, and I'll see what I can figure out. I appreciate the link to your item.
I know that Genesis 9 is new, but does anyone know of a morph that removes or reduces the size of the bulge from the male base morph? Dressing G9 Males in the female basicwear looks really strange without something like that.
Like this https://www.daz3d.com/forums/discussion/603561/g9-masculine-chest-smoothing-morph#latest ?
