Marble Texture/Shader Preset - Daz 4.8 beta
A marble shader preset -works in iRAY (edit 2 -not vray or even Lray!) ( to use in 3delight just set texture in the runtime folder and tile)
http://www.digi-dotz.com/index.php/free-poses/textures/66-marble-shader-preset-for-daz-studio-4-8
Forgive the website -is a bit funky
Post edited by DigiDotz on
Vray or Iray?
oh yes thats lray :)
In that case, thank you. :)
Actually it's IRAY, not LRAY.
thanks ! i already used them to improve a scene http://www.daz3d.com/forums/discussion/53869/P15/
i combined the texture with the supershininess of Marianne's Super-Shine shaders
what,,no is it!? OK folks it is "Iray" Im just a bit dizzy
+i'm honored it made its way to an original mCasual + thanks for your scripts again
Thank you for sharing the Shader :D
Thank you very much for sharing this.
Is it Iray and Studio 4.8 only? Or will it also work in 3Dlight and Studio 4.7.?
Charlie
for 3Delight try this, I forgot to test in 4.7 so let me know if its ok
I have added a version using base daz shader preset, just mess about with specular/glossy/tiling to your liking
Thanks. Image below shows a quick test in DAZ Studio 4.7 with no lights and default settings.
I downloaded and tried the ' DS4.7 and 3Delight' version. The shader preset Digidotz>Mable doesn't work (left sphere) Going deeper in the hierarchy, the one that is under 'Digidotz>mable>3Delight' does work but shows a seam (right sphere)
Hi Charlie
Just set the tiling to whole numbers and the seam should go away ;-)
Thanks. I can definitely use this shader.
I just did a very quick test with everything straight out of the box and no adjustments.
Charlie
Bumping the necro thread to say thanks for this! I've been trying to find a nice marble shader..weird how rare they seem to be.
Thank you DigiDotz. I test it in the next Time :)
