Marble Texture/Shader Preset - Daz 4.8 beta
DigiDotzDigiDotz Posts: 515
edited March 2015 in Freebies
A marble shader preset -works in iRAY (edit 2 -not vray or even Lray!) ( to use in 3delight just set texture in the runtime folder and tile)
http://www.digi-dotz.com/index.php/free-poses/textures/66-marble-shader-preset-for-daz-studio-4-8
Forgive the website -is a bit funky
Post edited by DigiDotz on
  • scathascatha Posts: 756
    Vray or Iray?
  • DigiDotzDigiDotz Posts: 515
    oh yes thats lray :)
    In that case, thank you. :)
    Actually it's IRAY, not LRAY.
  • mCasualmCasual Posts: 4,607
    thanks ! i already used them to improve a scene http://www.daz3d.com/forums/discussion/53869/P15/
    i combined the texture with the supershininess of Marianne's Super-Shine shaders
    edited March 2015
    what,,no is it!? OK folks it is "Iray" Im just a bit dizzy
    +i'm honored it made its way to an original mCasual + thanks for your scripts again
  • savannasavanna Posts: 31
    Thank you for sharing the Shader :D
  • Charlie JudgeCharlie Judge Posts: 13,633
    edited March 2015
    Thank you very much for sharing this.
    Is it Iray and Studio 4.8 only? Or will it also work in 3Dlight and Studio 4.7.?
    Charlie
    Post edited by Charlie Judge on
    edited March 2015
    for 3Delight try this, I forgot to test in 4.7 so let me know if its ok
    I have added a version using base daz shader preset, just mess about with specular/glossy/tiling to your liking
    400 x 454 - 223K
    edited March 2015
    Thanks. Image below shows a quick test in DAZ Studio 4.7 with no lights and default settings.
    I downloaded and tried the ' DS4.7 and 3Delight' version. The shader preset Digidotz>Mable doesn't work (left sphere) Going deeper in the hierarchy, the one that is under 'Digidotz>mable>3Delight' does work but shows a seam (right sphere)
    890 x 819 - 107K
    Hi Charlie
    Just set the tiling to whole numbers and the seam should go away ;-)
    699 x 431 - 50K
    edited March 2015
    Thanks. I can definitely use this shader.
    I just did a very quick test with everything straight out of the box and no adjustments.
    Charlie
  • ScavengerScavenger Posts: 2,677
    Bumping the necro thread to say thanks for this! I've been trying to find a nice marble shader..weird how rare they seem to be.
  • Thank you DigiDotz. I test it in the next Time :)
