• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Maya Discussion
Objects coming over through DazToMaya bridge displaced
tam_c3df5332fctam_c3df5332fc Posts: 126
November 2022 in Maya Discussion
Hey guys,
When I send the character from Daz3d to Maya, via the bridge, the objects (shoes and glasses) are displaced. I place them in their correct places.
Even after the retargeting process, the objects are where they are supposed to be, but once the animation starts, then the objects are once again displaced from where I would expect them to be.
See attached screenshots
How can I keep the objects positions relative to their parent?
And the shoes have their respective feet as their parent, along with the glasses having the head as it's parent
Thanks in advance
BTW, I will be leaving to work the evening shift and I maybe late in replying, but I look forward to returning from work to read your replies
  • tam_c3df5332fctam_c3df5332fc Posts: 126
    November 2022
    In case someone else runs into this issue, then this is the solution that I found.
    First, some errors on my part. I thought that by using the Transfer Utility on the objects (glasses and shoes) that this would make them fit better, but obviously, it causes other issues. So, I started by reimporting the objects without converting them using the Transfer Utility
    Second, I parented the glasses and shoes to the entire character, rather than, the shoes to the each foot and the glasses to the head
    Third, after using the bridge to Maya, I made some adjusments to place the objects in the correct positions, followed by using the Constrain> Parent option in the Animation tab - I have learned through this process, that I should select the parent first, then the child, followed selecting Constrain> Parent
    The result is that the objects now move along with the character - see attached screenshot
    BTW, does anyone know how to make the shirt fit with the pants' waist/pelvic area without the pants poking through? I know that I could probably use the mesh grabber to fix it, but there should be some kind of uniform solution to this - maybe I will try to finally learn how to do clothing simulation
    3076 x 1802 - 425K
  • Richard HaseltineRichard Haseltine Posts: 109,267
    November 2022
    Is your figure morphed? If so you need, when using the Transfer utility, set the Source Shape correctly and then enable the Reverse Source Shape from Target option.
    November 2022
    @Richard Haseltine
    Thanks for replying
    Can you give me some screenshots, so that I can follow along with what you are describing?
    November 2022
    Are the clothes modelled around a version of the figure with morphs, or a pose applied, or both?
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
