There is Snow in my Dinosaur's Complaint Thread
1151618202150
  • TJohnTJohn Posts: 11,418
    DS 4.8 Beta>Iray drop. :)
    1400 x 1500 - 431K
  • SerpentSerpent Posts: 4,075
    edited March 2015
    DanaTA said:
    plain water eels heavy in my tummy. weird thing.
    so much volume of snow, taking a long time to melt.
    ides of march. ole julius was having a rough day, way back. et tu brute`
    You have eels in your tummy? :ahhh:
    Dana
    OMG OMG OMG OMG OMG :ahhh:
    Post edited by Serpent on
  • ps1borgps1borg Posts: 12,776
    Morning. F1 car racing breaking the usual sleepy sunday morning feeling here today :)
    Gooooooooooooooooooooooooood morrrrrrrrrrrrrrrrrrrrrrrning :cheese: :cheese: :cheese:
  • starionwolfstarionwolf Posts: 3,670
    do you have subsurface shader base installed?
    I think I have it installed.
    Let me try Richard H.'s suggestion.
    431 x 159 - 30K
  • RezcaRezca Posts: 3,393
    Shaders are specific to a render engine for the most part. DS can make a reasonable stab at translating settings for the standard shaders to the Iray uber Base shader, but custom shaders or unusual settings for the standard shaders may well defeat it.
    Yup, though if the render engine has an exporter that is written to read a software's native shaders, then... Well, then it can xD
    Usually they stick to their own shaders though - and for the most part they're superior to a software's native shaders. Mental Ray seems to support native shaders just fine, though there's little reason to use them when MR has so much more potential. Vray and Indigo can't render native shaders (At least in Cinema 4D) and you need to convert them or make one yourself. They'll just render white if you don't.
    Might be wrong, but it seems unbiased engines are more picky with what shaders are used than biased ones.
    You specify how a surface will emit light (EDF) and how it will reflect light (BDRF) and the unbiased engine refines the image until the required level of detail is achieved. Biased ray tracers skip those refining steps using interpolation algorithms, which introduces artifacts and requires other steps to "clean" them up. The algorithms don't port to the unbiased engines because they aren't used, it is a completely
    different approach :)
  • kyoto kidkyoto kid Posts: 42,385
    TroutFace said:
    More playing with iRay, just for grins.. still horribly show on this machine but I can go off and do Other Things(tm) while it renders. I need to RTFM on lights, though.. scene appears quite dark, I know there's a thread on this somewhere... :blank:
    Take a look at [http://www.daz3d.com/forums/viewreply/778481/]posts 26 and 27 in this thread. SickleYield and DAZ_KatBriggs give some advice about lighting. You want to use the new photo lights. Sorry, I forgot the term. I'm away from my fast computer now.
    Also interesting: Using a null as the sun. There is a post about using the sun dial to position the sun in the latter pages of that thread.
    edit: forgot something as usual.
    ...learned of even a better method, If you go to Render Presets in the content tab where there is an Iray folder that has what is called the "Sun Dial Set": load this into your scene, expand it, and select "Sun Chain" then go to the Render Settings pane and change the Sun Node to "Sun Chain"as well. In the parameters tab you will find two controls "Elevation" and "Azimuth". You can use these to position the sun anywhere you want in the sky.
    TroutFace said:
    Her right arm and leg look washed out on my monitor. I think the LCD monitor is set too bright. I'll look at the render on my older computer. Thanks for sharing.
    The lighting is kind of iffy, this done in DS4.8 and I might have done something wrong... :red:
    ...looks OK to me.
    ...looks OK to me.
    Is looking good for me, IPad, I'll take a look on a monitor when we get home.
    *waves* we refugeed ourselves to the outer suburbs for the day :lol:
    edited March 2015
    TroutFace said:
    complaaaaaiiiinnnnttt -zip files with 0kb files in it don't fully unpack.
    i gotz a whooole bunch of near empty folders with single png,
    i'll have to go through every folder, re d/l :shut:
    and no BEER
    thought it was just character folders, hexxus sword - betrayed woes
    NO BEER OMGGGGGGGGGGGGGGGGGGGGGGGGGG :ahhh: :ahhh:
    ...must be in "Heaven" then. ..:cheese:.
    https://www.youtube.com/watch?v=aZObXQe1lqI
    Post edited by kyoto kid on
    edited March 2015
    Dana
    no wonder my tummy hurts >.<</div>
    ...I left my eels in the hovercraft.
    600 x 350 - 124K
    ...yeah having heck of a time getting rid of some white artefacts in the hair of one of my characters. (April YSH's Osean Hair). Converted the hair shaders to the Iray base but adjusting the glossiness and reflectivity sliders in the surfaces tab seems to be of f little help
    big guanna came out to play.
    1600 x 1066 - 2M
    as suspected, iz caturday
    ISTR hearing the advice to make sure there's a spec map for the hair.
    <3 Biguanas :)</p>
  • DanaTADanaTA Posts: 13,407
    That was cool.
    Dana
    edited March 2015
    ...there's only an opacity and bump map. Opened the textures folder and all could find along with the diffuse texture maps was a single map titled aprosean_trans which appears to be the opacity map. The bump map is apparently part of the individual diffuse maps. There is also no displacement map.
    Would have no idea how to go about creating a specular map.
    Update:
    Reapplied the original hair map again as I noticed there were were also SSS setting channels in the surfaces tab. When I originally created the scene for 3DL and Reality/Lux, I must have applied SSS to soften the hair a bit as it looked kind of
    "plasticy" . When I started a new render, I noticed most of the artefacts (save for one on the front of the scalp layer) were gone so it must have been something to do with the SSS settings. The only issue now is the hair looks almost transparent. I'll have to check the Iray Hair thread tomorrow to see if there is a solution for that as it is late (actually early morning) and I need to knock off and get some sleep.
    edited March 2015
    breezy day.
    sittin, mindin my own business, bone gnomes attacking my finger joints. oscar whisky
    >.< holding coffee cup setting off ow sirens.
    watched a bunch of cripeman tutorials. me thinks can spline model a pipe and chain links :)
    uv unwrapping, not so confidant about
    rendering v6hd to image lil faster than rendering to window. faster is relative. :lol:
    need to learn how to use the standalone 3de.
    need to learn how to skype.
    need to sleep a few more hours,
    didya ever like have that lil bit of skin loose from the roof of your mouth?
    is impossible to ignore, but it's not going anywhere?
    876 x 532 - 236K
    Post edited by Mistara on
  • atticanneatticanne Posts: 3,009
    It's shaping up to be too beautiful today to stay inside on the computer. Time to dispel weeds from the flower beds and play in the dirt.
    Already sunny and 51F here, should hit 73F.. looks like I'll go out for a few beers later today! :cheese:
    Time to compose some music! :cheese: Sip sip coffee out of cute raptor mug, need one for work now.. :)
  • XyetztXyetzt Posts: 27,546
    We are never ever getting back together, ever! Does anyone know of any good breakup songs that can help me remember that I am never ever getting back together with him!
    edited March 2015
    Please release me by Englebert Humperdinck worked quite well with my ex-husband. Not sure if it was the words or thw fact that I had copied it several times onto one cassette tape which I played over and over.
    https://www.youtube.com/watch?v=6S9ecXWCBCc
    Post edited by Chohole on
    Here are two renders one iRay and one 3delight
    1000 x 1000 - 1M
    1000 x 1000 - 2M
    edited March 2015
    I notice there are actually shadows in the iRay one :)
    Something I tend to see a lot in Poser / D|S renders, is that it seems like characters and stuff are just.... Floating there. With no shadows underneath 'em. Not all the time, but I do notice it now and then.I don't really know why, I mean if there's light there should be shadow yes? Maybe it's an ambience thing or something....
    Post edited by Rezca on
  • frank0314frank0314 Posts: 15,090
    Make sure shadows are turned on on the light
    There are several reasons for that. One is that they don't know how to do it, where to find the switch to turn on shadows (even though it's not that difficult). Another is they just don't pay attention to detail. And finally, there are those who just don't have enough computer to handle shadows...it does take more resources. It's hard to imagine, but there are still a lot of folks who don't have more modern computers with more memory and faster processors. Not everyone can keep upgrading their boxes with the latest and greatest tech. I always try to make sure there are shadows. Over in the Freebie Challenge, it is one of the things that help make the winners come out ahead. Points are taken if there are no shadows.
    Dana
    Dana
    It's the other way around in Cinema 4D, where you have to go out of your way to disable the shadows for lights :lol:
