Q about X-Fashion Antihero Outfit
Hera
Is it possible to cover up the ears in this outfit? I like everything about it save for those holes for the ears.
https://www.daz3d.com/x-fashion-antihero-outfit-for-genesis-3-female-s
Post edited by Hera on
I took the risk and bought it, probably for the same reason you're thinking of but to answer your question, no you can't cover the ears or eyes. Slightly disappointing.
I guess you could use a geometry shell to fill in the missing pieces and apply a shader to it that's a decent match. Then add a transparency mask to cover/reveal the desired areas.
You could also use the No Suit morphs if you have them, then color the skin in that area on the texture map.
Thanks for the suggestion, I might try rhythm over the weekend. I have the No Suit Morphs.
I tried out the suggestion to use the no suit morphs. It works quiet well and I've posted a picture in the gallery
Another suggetion, From ma y years addited to comics, A morph that raises the mask enough to uncover the mouth and bottom of the nose could be useful. You know, for when our hero deserves a little extra thanks before the cops show up.
You're not likely to get results making suggestions in a five-year-old thread in the Commons about a now two-generation-old outfit made by someone who, as far as I know, does not read the forums. That said, JoeQuick made a Spiderman outfit for M4 that has such a morph. It's available on ShareCG. I once used it to render a twist on the famous kiss scene in the first Sam Raimi Spiderman movie that I absolutely could not post here.
