Q about X-Fashion Antihero Outfit
HeraHera Posts: 1,970
edited July 2017 in The Commons
Is it possible to cover up the ears in this outfit? I like everything about it save for those holes for the ears.
https://www.daz3d.com/x-fashion-antihero-outfit-for-genesis-3-female-s
Post edited by Hera on
  • LesPaulLesPaul Posts: 50
    I took the risk and bought it,  probably for the same reason you're thinking of but to answer your question, no you can't cover the ears or eyes. Slightly disappointing.
  • pdspds Posts: 593
    I guess you could use a geometry shell to fill in the missing pieces and apply a shader to it that's a decent match. Then add a transparency mask to cover/reveal the desired areas.
  • RKane_1RKane_1 Posts: 3,039
    You could also use the No Suit morphs if you have them, then color the skin in that area on the texture map.
    Thanks for the suggestion, I might try rhythm over the weekend. I have the No Suit Morphs.
    edited August 2017
    I tried out the suggestion to use the no suit morphs. It works quiet well and I've posted a picture in the gallery
    Post edited by LesPaul on
  • Another  suggetion, From ma y years addited to comics, A morph that raises the mask enough to uncover the mouth and bottom of the nose could be useful. You know, for when our hero deserves a little extra thanks before the cops show up. kiss
  • GordigGordig Posts: 10,799
    edited November 2022
    You're not likely to get results making suggestions in a five-year-old thread in the Commons about a now two-generation-old outfit made by someone who, as far as I know, does not read the forums. That said, JoeQuick made a Spiderman outfit for M4 that has such a morph. It's available on ShareCG. I once used it to render a twist on the famous kiss scene in the first Sam Raimi Spiderman movie that I absolutely could not post here.
    Post edited by Gordig on
