Nipples lower on G9?
background
in The Commons
I've been doing some experiments on converting G3F shapes and textures onto G9. I did this by matching G3F with the G9 G3F clone shape applied and then transfering the texture accross This seems to work but the converted texture puts the nipples textures higher on the breasts on G9 then the DAZ supplied G9 female textures. This can be seen without converting anything, by putting a G9 female texture onto G9 and dialing in the G3F clone shape. Put next to a base G3F with a G3F texture applied the difference in nipple height is noticable.
Maybe I'm messing the conversion up but i don't think so.
If this is a thing then it's going to make converting older textures a bit more awkward.
Where are those Clones for G9?
Can be found on the Parameters Tab under "Hidden" [may have to go the hamburger menu {lines} to toggle Show Hidden on].
The clones in G9 are created and optimised for transferring clothing, which is likely why you're seeing the difference in nipple height.
Do the nipples in G9 have a proper shape or are they still the truncated cones as in G8 and before?
g9 don't have "nipples" unless you use high level of resolution(nipples are build in a lv3 or high) base level(nothing) or level 1 to 2 they will be "triangles even worst than pervious genesis. or you "buy" nipples for g9, you know the famous "less is more".(less free content more to buy)
the same goes for navel, g9 is more like the "doll character" generationat low level, because details only if you use the hd making base or low level resolution almost useless if you are aiming for realism.
I am kind of curious if nipples could be done like "Pasties", in that you could put them where you want them, and color them to your liking....
I don't think they could be done in a way that would slide around the surface of the skin while always maintaining contact, if that's what you had in mind.
I havent tried this out so not sure how good it is, still delaying messing with G9, but this is something I found the other day. Nipples Add-on for Genesis 9 - Daz Content by rendorgal (renderhub.com)
