Something in my eye: Weird problem with eye surface or geometry or somthing
ScavengerScavenger Posts: 2,677
I've found, when I went for a close up of a model's face I set up, something weird with the eye...a..line? of white between the lower lid and the eyeball.
I've changed the opacity on a few of the suraces to try to identify this but so far no luck.
Anyone know what I'm seeing here?
  • scorpioscorpio Posts: 8,533
    Possibly the 'Tear' surface.
  • ScavengerScavenger Posts: 2,677
    I'm 90% sure i tried 0'ing that to no effect, but i'll check again.
    Check the reflection and the spec I remember once having a problem and even with the opacity and diffuse at 0 the reflection caused a problem.
  • Eustace ScrubbEustace Scrubb Posts: 2,734
    Take a look at the refraction values as well, or just apply a water shader to the "tear" surface.
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    That is the Tear surface. If you are rendering in Iray and start with the new (updated) G2F or G2M base and apply your character preset, or material preset to that, it should, presuming nothing out of the ordinary was done to these surfaces, automatically perform a special translation to the Eye Reflection, Cornea and Tear surfaces.
    Thanks! It looks like it was the Specular setting on Tear. it was at 50%, (opacity WAS at 0) moving it to 0 got rid of it.
    333 x 113 - 62K
    Hmm, I don't appear to have one of those...what I did have which I thought was water, made a solid bar across the lid. oh well.
    Hmm, I don't appear to have one of those...what I did have which I thought was water, made a solid bar across the lid. oh well.Try Fisty's (updated) Liquids, from http://blackraven3d.com/sponsored/fisty/freebies/
    Second the motion on that one...
    Note that simply zeroing Opacity doesn't remove the effects of other parameters; Specular, Reflection, Refraction etc. all have valid reasons to still work in some way, even on a completely transparent surface. Make sure everything is zeroed, and all attached texture maps removed.
  • nobody1954nobody1954 Posts: 933
    Thank you for that link. Don't think I'd seen it before.
    Good to know! Thanks!
