Manual Install Figure Runtime Folder
tdctdc Posts: 139
So, I found an old figure, it's in a Runtime folder. In that folder is a Geometries, Libraries and Textures folder. But for the life of me I can't install this Character.
How do I install manually? I can't use DAZ3DIM can I? If not, how and where do I place these file so DAZ3d Studio sees these files?
I have a MAC by the way....
Thanks in advance.
    There's a couple of ways of doing it.
    One, if you can live with where it is currently located, just go to the Content Directory Manager in DS and add that Runtime to the Poser formats.
    If not, you can manually merge it with an existing mapped folder...look at where the existing mapped Poser format files are located and merge it.
    I'd probably take the first option.
  • ioyo2000-vpioyo2000-vp Posts: 10
    edited March 2015
    Looks like poser format. Copy it into your Daz folder manually and find it in the poser content section of the Content Library.
    Edit: Poster above gave a better answer and I'm unable to delete this post, which is now useless!
    Post edited by ioyo2000-vp on
  • tdctdc Posts: 139
    First option worked, I thank you!
