Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
That's odd, I cannot get any tabs beside the ones that are shown in my pictures.
I reinstalled it already, why is Studio hiding my tabs >>
No network rendering at this time.
I see, shame I can´t see how much time´s left since the render view is blocking that slider. But at least I can tell by how noisy the image looks whether it´s ready or not : )
This is my view, I really feel lost lol
Can you point out as to where I should be looking?
I usually just right click and add it so other methods are unknown by me ><</div>You didn't happen to have DAZ Studio open when you installed the Beta did you?
Oh erm, I did as I am working on something...let me retry...
EDIT
Closed everything down, uninstalled and reinstalled: no difference.
Also on hte render progress window you can hit cancel if you think it is done, and then save the image.
I moved my Iray image over to the to the Unbiased Render thread...
What about existing shader products... do they work with this new render engine? For example amazing skins.
Are your content locations mapped?
Kat
I got it!!! It just got disappeared under here:
But I managed to get it back.... sorry for the n00bness.
It will stop at about 95% convergence. While it "can" continue to render, we put dome default stopping points in there. :) They can be adjusted to your personal liking for an image.
Kat
If you look at the render tab with Iray selected You'll find a 'max samples' and a 'Max Time' - it looks like the default is to run to 95%, as Kat said, or for 5000 samples (iterations?) or for 2 hours (7200 seconds); presumably the first reached will terminate the render.
I just got this downloaded and installed - need to see what I can do tonight with a GT 740 (4 GB, but only 384 cores :-( ).
Whoop whoop whoop! *Does the unbiased render dance* Let's try it with a Constrictor promo.
I turned off the CPU and let my two GTX 740s and two GTX 980's work on this without it. It took about 7 minutes at this 1000x1300 size. This is four 4 gb cards, although the 980's are so far out ahead that turning off the 740's doesn't slow things down that much. One of them pretty much is just running my display according to the way GPU-Z behaves.
I tried it with the CPU on too, but it actually slowed way down.
Is there any info on how Studio is converting shaders to IRay? Does IRay itself grok Renderman so it can mostly just pass the same stuff it generated for 3Delight to IRay? Or does it have its own entirely unique shader language, and so Studio is having to convert stuff and how much control do we have over that conversion? E.g., look at any of the other exporters (Reality, Octane, etc) -- they provide default conversions based on edumikated interpretations of the Studio shader settings, but still require tweaking to get the best results out of the native rendering engine. Especially converting to native materials like metal and glass.
If Studio is doing conversions, then what is supported? E.g., DAZ is providing default translators for DzDefaultMaterial, UE2, AoA (I'm assuming, since a lot of recent characters have switched to this even though it is a ShaderMixer network)? Anything else? What about any old arbitrary custom ShaderMixer network (e.g., Parris' Bot stuff)?
Does IRay do hybrid GPU mode (so you don't need massive amounts of VRAM to load all the textures)?
Course, this is unlikely to get me to change my workflow (Studio -> Reality -> LuxRender) since I don't have an nVidia GPU and don't plan to switch anytime soon.
Yeah, the workstation I am sitting on at this moment is my 4 x Tesla. I selected only the Tesla's in the advanced settings, but while rendering my CPU is pegged @ 100%. Any ideas?
...well that's 340$ which I don't have (GTX970). According to Richard, he could barely render a single naked Vicky with 1GB of VRAM.
I tend to do some very involved scenes.GTS 740 with 4GB of RAM is around $100. (Didn't we have that conversation a few months ago?)
...just went to Newegg: 339$
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487088
Shaders are render engine specific. With those shaders that could be translated. we did our best, but most can not.
Note you can still use 3Delight, and in fact this beta does include a new build of 3Delight as well. :)
...how much slower? If it's Luxrender or even UE slow, than I'll stick to Reality/Lux as at least I don't have to keep the scene or even the Daz application open once the scene is sent to Lux. Depending on your lighting and scene, on average, abouot the same speed as 3Delight. (Note when I say that, I do mean you have to actually light your 3Delight scene, not just use the headlamp.)
Correct - comparing to a correctly lit 3delight scene, my stuff rendered about the same or a bit faster. But the result was better. So if you are looking for super fast, it will cost hardware. If you are looking for quality, well, that's why many of us have tried other renderers isn't it? Even the slow ones made us happy because we liked the results. :)
Kat
...however you still need to keep the scene and Daz application open until the rendering is complete whereas as I mentioned with Lux you can close everything once the render job is handed off.
You really don't want to go at this with one 740 if you can get one or more 980's instead. I can tell you that right now just from unchecking different stuff on my own system. But if you've got $100 to spend ($120 actually), don't get that 740, get this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487047
Yeah, the workstation I am sitting on at this moment is my 4 x Tesla. I selected only the Tesla's in the advanced settings, but while rendering my CPU is pegged @ 100%. Any ideas?Not sure, and without more information I can guess, but I would probably be wrong. Could you please open a support ticket, and include the DS log, a scene file that does this and a list of what is in the scene.
Thanks.
My first render with Iray. Sky set to 4 PM + one mesh light with the emission Iray shader.
All the lights have default settings, I only applied the Iray skin preset to Lilith.
Took about 30 minutes. Still a bit noisy, should have turned the quality up : )
Sickle, your constrictor looks AMAZING!
Thanks!!
Good start. If you have a good graphics card (or more than one) uncheck your CPU, in my testing that actually goes faster.
...agh! got the numbers on the GPUs wrong, apologies.
However when it comes to Pure GPU rendering doesn't having more CUDA threads give better performance? The 740 only has 384 while the 970 has 1,664.
Thanks.
Well... actually it looks like it is only using the CPU for Iray and not the Tesla's. Let me start a ticket, I can include the DS log and a GPU-Z screen capture. I was using all 4 cards in Octane just before this thread started, so the hardware works. Just maybe not with Iray just yet. In my mind, probably a driver issue...
Derp! I thought you linked another model of 700 and something. Yes, a 970 is definitely a better choice than a 740 if you can afford it, and yes, more CUDA threads is better as I understand it so far.
I'm out about $1k for my two GTX 980's and about $250 for the two 740's. The 740's do not even come close to the performance of the other two, unfortunately.
780 GTX has 2304 CUDA cores under the kepler architecture. The 970 GTX has 1664 under the Maxwell architecture. So you cannot really apples to apples with this. I can tell you that the 780 GTX dominated the 970 GTX in Octane, but I imagine that is not a straight comparison for Iray.
Very nice! :)
As Spooky was saying in another recent thread, you can have more than one video card (non-SLI/Crossfire) and let one, lower end, do the display while another, higher end, does rendering (I guess Iray is why he was mentioning that).
Kat
You still have the ability to use Lux. :)
That looks great :)
Restarted the pc, tried installing it in a different path etc. etc.
Still it won't show me all the tabs.
Going to catch some sleep now and try again tomorrow!
This is so frustrating ><</p>
EDIT
I always install Studio manually because I ran into problems when I let DIM do it.
Is there no option for me to install 4.8 manually as well?
