Has anyone seen a short sleeved version of a similar t-shirt?
in The Commons
Hello,
I have been trying to find a short sleved version of a shirt that is similar to the one in the attached image. The original product is by outoftouch. If anyone knows where I can find one it would be greatly appreciated.
Thanks in advance for any replies.
nabob21
Can't you just make a transparency map and make the sleeves shorter on this one? Or have you not purchased this one?
I haven't purchased it yet, and was waiting to find out if there is a short sleeved version before I before I went ahead did purchase it.
There are no short-sleeved henley shirts that I've seen. There are other long-sleeved ones, but for male characters only, as far as I know. Using a transparency map would be a poor solution, as you would lose the cuff detail. If you want, you can try to alter existing textures, though it probably won't look right.
Anyway, it's a well-made garment, and there are lots of additional texture options available. Just note that it is not made for dForce.
You can select 'Sleeves" and "Sleeves" trim in the surfaces tab and set the opacity to 0%.
Thank you for the replies Sevrin and ArgleSW.
