Has anyone seen a short sleeved version of a similar t-shirt?
nabob21nabob21 Posts: 1,058
Hello,
I have been trying to find a short sleved version of a shirt that is similar to the one in the attached image. The original product is by outoftouch. If anyone knows where I can find one it would be greatly appreciated.
Thanks in advance for any replies.
nabob21
  • FauvistFauvist Posts: 2,290
    Can't you just make a transparency map and make the sleeves shorter on this one?  Or have you not purchased this one?
  • nabob21nabob21 Posts: 1,058
    I haven't purchased it yet, and was waiting to find out if there is a short sleeved version before I before I went ahead did purchase it.
  • SevrinSevrin Posts: 6,314
    There are no short-sleeved henley shirts that I've seen.  There are other long-sleeved ones, but for male characters only, as far as I know.  Using a transparency map would be a poor solution, as you would lose the cuff detail.  If you want, you can try to alter existing textures, though it probably won't look right.
    Anyway, it's a well-made garment, and there are lots of additional texture options available.  Just note that it is not made for dForce.
  • ArgleSWArgleSW Posts: 161
    edited October 2022
    You can select 'Sleeves" and "Sleeves" trim in the surfaces tab and set the opacity to 0%.
    1227 x 1986 - 2M
    Post edited by ArgleSW on
    Thank you for the replies Sevrin and ArgleSW.
