g8 fur won't equip to g8.1
UpiriumUpirium Posts: 728
edited October 2022 in The Commons
I'm using tom cat at the moment that I use for other things, but noticing now that the fur for the torso will not apply to g8.1. I tested it on g8 and it seems to work.
Its not just tom cat though, it's every character I have that's for g8 that uses torso fur.
Is there a work around for this?
pic for reference g8.1m and g8m.
Image removed
    I've made a crown that has a fur brim and I've noticed that it looks fine...until I move it. No matter what I do, it will not parent correctly. It moves with the crown, but part of it is embedded in the rim. I'm wondering if the same thing is happening here with G8/8.1
    Have you tried applying skin from a G8 figure to the G8.1 before loading the fur?
  • UpiriumUpirium Posts: 728
    yeah i have. i applied that skin on g8.1 first, then the fur. and you can see what happened
    but as you can see i applied the fur directly to g8 with no issues
  • It's probably because the surface group names have changed. Which character is this?
    Yeah, tried it myself and the G8 fullbody fur doesn't load to areas of the G8.1 that belong to the new Body and Head groups, which is named the Torso group on the G8
    Tried with the Genesis 8.1 Basic Male and the fur from Gorilla 8, the skin from the gorilla applies correctly though.
