Does anyone know what hair is used in this render?
MuzMelMuzMel Posts: 76
edited October 2022 in The Commons
[Does anyone know what hair is used in this render?] :)
  • What makes you think it is any standard hair?
  • kyoto kidkyoto kid Posts: 42,365
    edited October 2022
    ...not sure what hair content that is however some hairs have separate material zones and using a hair shader like Slosh's UHT2 Ultimate Colour can create such results.  Here is what I did with Callista Tail Hair which has separate mat zones.
    849 x 1200 - 400K
    Post edited by kyoto kid on
  • Could be Ezra Hair. It's possible to give dForce hair multiple colors using a texture map even if it only has one material zone.
  • alienareaalienarea Posts: 547
    It looks like two hairs combined to me. The white hair seems to have better quality.
  • GatorGator Posts: 1,320
    It also might not be hard with the Geometry editor tool, you can usually select a part and then use the two key CRTL + (each time to increment the selection) to follow up the mesh.  If there's a fair amount of separate strands that will work and might be easier if the hair already comes with separate white and brown textures.
