• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic produces two tongues if Lickalicious is attached
DendyDendy Posts: 6
October 2022 in Blender Discussion
Hello, hope somebody could help me out or point me in the right direction, I'm using Diffeomorphic and if I import a character with the Lickalicious tongue attached it produces two tongues in Blender, basically I have the Daz model tongue and the Lickalicious one, see attached screenshot. I'm now wondering if it is a limitation in Diffeo, a bug or I am doing something wrong.
  • PadonePadone Posts: 4,065
    October 2022
    Probably you didn't merge the geograft.
  • DendyDendy Posts: 6
    October 2022 edited October 2022
    Thank you for the suggestion; I've attached two screenshots, my easy import settings and the result; as you can see, I've selected the setting <<Merge Geografts>> but the model still has two tongues.
    428 x 2017 - 159K
    3839 x 2079 - 5M
    Post edited by Dendy on October 2022
    I see lickalicious is a nested geograft, that is, it includes two geografts linked to each other. In this case do not "create duplicate bones" or you will get a double set, also do not "merge uv layers" since it may not work for all cases and confuses the plugin. Blender doesn't need to merge uv layers that is for game export only, and it is better done by hand since the automatic merge may fail in some cases.
    Tested both with easy import and manual import and works fine here. Settings attached.
    245 x 504 - 26K
    Post edited by Padone on October 2022
    October 2022
    Thank you for your help, Padone. I tried your suggestions and settings and it solved the "double tongue problem," but now I have a follow up problem with the rigging of the tongue. If I convert the character rig to MHX or Rigify, I can no longer pose the Lickalicious  tongue in Pose Mode (see screenshot), and I tried many things within Easy Iport (see screenshot with example settings) and Daz Import, but without success. I also noticed that the character has two tonge rigs attached to the Daz Rig (see screenshot with blue outline), so perhaps the conversion to MHX causes the deletion of the Lickalicious rig, which causes the posing issue. I'd love to know if you got the posing to work on your site and the settings you used.
    502 x 1970 - 164K
    3839 x 2044 - 2M
    1013 x 547 - 197K
    No that's just normal and is how geografts work. That is, geografts will not delete the daz bones, they just add their own bones, the geograft bones will be in the custom layer in mhx. Then since lickalicious replaces the daz tongue you have to use the lickalicious bones to pose the tongue, not the daz bones. The mhx rig will use custom shapes for the daz bones but of course leaves the geograft bones as they are.
    Screenshot attached, you have to use the lickalicious bones to pose the tongue.
    edit. note. As a side note, not related to lickalicious, there is some confusion in your settings. We probably need to simplify the simplify settings LOL.
    1. You should either use units + expressions + visemes or facs + facs expressions, not both together.
    2. The body morphs are only needed to help posing the daz fk rig, they're not compatible with the mhx/rigify ik rigs.
    467 x 211 - 32K
    October 2022
    Great, thanks again, Padone, for the detailed explanation; I just tested it, and everything works great now. ) "We probably need to simplify the simplify settings" haha)) yes, I suppose you need to simplify them for people like me, lol) Thank you for pointing out how to use the settings properly; have a great day)
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
