Wafty flappy long coat or cloak for G8 male
Pitmatic
in The Commons
Hi Guys
Any suggestions for a long flappy coat or cloak but possable or with morphs I am thinking along the lines of David Boreanaz's Angel character in style?
I really dont want to use deforce for this ideally for G8 male
thanks
Check out Yura's Western Outlaw 2.
The set is for Genesis 3 Male but you can use it on Genesis 8 Male.
-Make sure you don't have anything selected in the scene and load in the coat and make sure it's selected
-Got to "Edit-Figure-Scene Identification"
-In the Window that pops up change the very bottom dropdown box from Genesis 3 Male to Genesis 8 Male and hit accept
-In Parameters in the General Tab go to "Fit To" and select Genesis 8 Male and you should be good to go!
To hide the shoulder cape and its buttons just go into the surfaces tab and slide the opacity dial to 0 on the Buttons 2 and Coat 1 mat zones.
I had to look up a picture of his coat, as I was looking for something more along the lines of something Spike would wear. I did find this: https://www.daz3d.com/hc-trench-coat-outfit-for-genesis-8-males which you would need to use leather shaders on, but it has a length morph and is not dForce, but it is not exact as to the pockets. It also comes with some pants that look like the ones Angel wears also.
Thnaks for that turned I shall have a look see what I can do :)
