Wafty flappy long coat or cloak for G8 male
Hi Guys
Any suggestions for a long flappy coat or cloak but possable or with morphs I am thinking along the lines of  David Boreanaz's Angel character in style?
I really dont want to use deforce for this ideally for G8 male
thanks
  • Check out Yura's Western Outlaw 2.
    The set is for Genesis 3 Male but you can use it on Genesis 8 Male.
    -Make sure you don't have anything selected in the scene and load in the coat and make sure it's selected
    -Got to "Edit-Figure-Scene Identification"
    -In the Window that pops up change the very bottom dropdown box from Genesis 3 Male to Genesis 8 Male and hit accept
    -In Parameters in the General Tab go to "Fit To" and select Genesis 8 Male and you should be good to go!
    To hide the shoulder cape and its buttons just go into the surfaces tab and slide the opacity dial to 0 on the Buttons 2 and Coat 1 mat zones.
  • memcneil70memcneil70 Posts: 6,098
    I had to look up a picture of his coat, as I was looking for something more along the lines of something Spike would wear. I did find this: https://www.daz3d.com/hc-trench-coat-outfit-for-genesis-8-males which you would need to use leather shaders on, but it has a length morph and is not dForce, but it is not exact as to the pockets. It also comes with some pants that look like the ones Angel wears also.
    900 x 900 - 795K
  • PitmaticPitmatic Posts: 1,021
    Thnaks for that turned I shall have a look see what I can do  :)
