Moving my library
Hi sorry if this has been covered before but how do I move my Daz installation or aspects of it without uninstalling and reinstalling everything please?
It seems I have run out of space on my c drive due to Daz Studio.
Daz Studio doesn't care where your content directories are, or what theya re called, as long as it is told about them. If you install through Daz Central or Install manager those do record the full location, starting from the drive, and so should ideally be updated (if you use Install manager and keep the zips after installing you can just change the destination, then select things in the installed tab and use the right-click menu to reinstall using current directories).
I did this a couple of years ago. I made this thread about it, and linked to another that gives step-by-step instructions
https://www.daz3d.com/forums/discussion/332926/moving-daz-assets-from-one-drive-to-another
I don't use Daz Central, so there may be extra steps to take if you do.
